Author Topic: how to save a boogered up spark plug hole thread?  (Read 29 times)
« on: September 07, 2026, 08:48:23 PM »
well...my Nighthawk 650 has been in pieces all summer. Today I decided to take my 3rd try at getting cams, sprockets, etc. back in with the correct timing. I successfully got everything installed and timed correctly! I was so happy. Started to put spark plugs back in and plug #3 was not going in easily by hand like the other 3. even with a ratchet on it it was taking more force than I was willing to put on it to get it back in. Removed and retried , gently, a few times. No luck.
Took a pic down the plug hole and you can see the threads messed up a little about halfway down. Ive posted this on my Nighthawk forum but thought I'd post here, too, as this is a relatively common engine problem. Any suggestions on how to proceed?  Thanks!  (hope Ruffus knows this forum is back online...)
Re: how to save a boogered up spark plug hole thread?
« Reply #1 on: September 07, 2026, 10:12:47 PM »
all right, looks like I've found a solution...a back tap thread repair tool, for spark plugs! It is inserted in the plug hole, expanded then pulled back out while turning to chase the threads. It captures any metal because it is pulling out of the hole, not going in. Brilliant. Learn something new every day!
