Author Topic: replaced center pad and cheek pads in helmet  (Read 677 times)
« on: June 09, 2026, 06:43:40 PM »
While I am waaay overdue for a new helmet (10 years old...) I thought I'd at least replace the worn out helmet pads with new ones for my Shoei R-1200.
I hadn't realized how much looser the helmet had become over the years. With the new pads it fits like it did when it was new (back in a previous decade..)
I also gave it a good cleaning on the exterior to remove the dead bugs, etc.  I probably should have also replaced the chin curtain as that is looking a little rough. Now I need the outside temps to lower a bit so I can get back on the bikes.
monkeybongos
  • Tampa, Fl
Re: replaced center pad and cheek pads in helmet
« Reply #1 on: June 10, 2026, 11:04:07 AM »
Where did you get the new pads, Hawk?
I need a new center pad for a Shoei…
Guessing Shoei’s website?
2016 Wolf V-50 (sold)
« Reply #2 on: June 10, 2026, 01:13:28 PM »
I got mine from Revzilla. I'm sure most any site that sells Shoei helmets will also sell the replacement pads? The Revzilla site did a good job with explaining the various options in pad thickness you can get as you are able to buy thicker or thinner replacement pads if desired.
Helmet smells a lot better, too!
« Reply #3 on: June 10, 2026, 09:13:36 PM »
I've got replacement pads for my Arai and Shoei helmets thru my local dealer, they are dealer for both brands, + HJC and maybe some others
« Reply #4 on: June 11, 2026, 12:23:02 AM »
I've both replaced or washed mine. Smells great in here now🙂
Recently read a fellow praising his old helmet for saving his head, twice!, in crashes.
There are opinions that helmets should be replaced after a certain number of riding years - open to some debate - but not much debate about the safety of replacing a helmet which has been struck in a crash - and after two??!!
« Reply #5 on: June 11, 2026, 12:34:17 AM »
Hawk - is your visor this dark - or is your movable tinted addition in its drop-down position?
« Reply #6 on: June 11, 2026, 12:44:11 PM »
Stig, It looks a lot darker in pictures. It is the light tint visor option. When looking directly at the helmet it appears so dark because you don't see any light behind it. Attached a pic with the visor raised so you can see through it and added one pic viewing through the visor.
I like it because it gives me some sun protection in the day and it's light enough to ride at dusk, if needed. If I think there's a chance I could be out after sundown I'll switch to my clear visor.
« Last Edit: June 11, 2026, 12:53:31 PM by Iahawk »
