Author Topic: Some good sources for repair parts  (Read 13392 times)
mrmike
  • Syracuse, NY
« on: June 05, 2026, 11:30:51 AM »
  I have a '23 People S 150 ABS. What are some good sources for repair parts like belts, air cleaners, etc.
Re: Some good sources for repair parts
« Reply #1 on: June 05, 2026, 01:16:52 PM »
For parts I would always keep in mind your local Kymco dealer (or a dealer that sells online). Some items in the future may need to be OEM. For other parts (hoses, bulbs, brake pads, rollers/sliders, filters, bearings, levers, etc.) you can do a Google search for scooter parts. I just did and large number of online retailers show up.
In your particular case, where there are not many People S 150 scooters around, you'll want to dig deeper into the sites to see if they list your specific model of scoot.
I clicked on scooterpartsco.com, Kymco and then under People S 150. It listed a number of parts. Some look to be interchangeable with other Kymco 125/150/200 cc models.
I think this question gets asked a lot on internet forums...which is best?...but there are so many variables.  Usually you have to find a site that has your needed part and then compare prices with another site or 2 or three.
ebay and Amazon are also viable options for many parts.
It seems like Kymcos are very well made and the only items you usually need are a belt, brake pads, air filter and spark plug to keep you going for many miles.
« Reply #2 on: June 05, 2026, 03:36:19 PM »
I agree Hawk!
Purchased my 2012 LIKE200i new in 2013 - and once the (faulty batch of-) TPS was replaced under warranty  - it has only needed oil changes, tires, belts & rollers. The brake pads are still fine, all bulbs are stock, etc.!
blaudp79
« Reply #3 on: September 26, 2026, 09:18:19 PM »
I'm in Ontario, Canada and it is hard to find Kymco parts here locally. I bought a bunch of parts recently from Europe from this site directly: https://www.brixiamoto.com/
Their prices are very good and they have non-OEM but good quality aftermarket parts too. For example, you can get Bando drive belt instead of the OEM Mitsuboshi one for 1/3rd of the price or less. They carry aftermarket Athena gaskets too. The complete gasket kit is very pricey, so I only bought the one for the CVT system cover, since it is very large. I used 5mm gasket stock from Aliexpress for other areas, like the final reduction cover plate for example. You just need strong good quality scissors and a punch kit. I recommend using Aliexpress for all O-rings and you can switch from standard Buna-N rubber to FKM (Viton) for longevity. I was able to find all the sizes I need. For high quality SKF bearings I recommend this ebay seller from the Netherlands: https://www.ebay.ca/str/benna27robin (Robara Industries). I've bought 2 X 6205 exporer series open bearings for $20 USD shipping included. Shipping cost is very low if you order small qty. (First bearing was $15 and the second additional bearing was $5) I bought all my shaft seals from Aliexpress too. Not all sizes are available in FKM though, but for sure you can find it in regular Buna-N.
This Taiwanese ebay seller carries OEM Kymco parts: k3428311 (https://www.ebay.ca/sch/i.html?_ssn=k3428311&store_name=k3428311). Filters are usually available via local generic motorcycle web shops or Amazon. Here in Canada HiFlo air and oil filters are easy to find.
« Reply #4 on: September 27, 2026, 01:19:44 AM »
thanks, helpful info!
« Reply #5 on: September 27, 2026, 02:00:58 AM »
I've purchsed NACHI Japanese bearings on ebay for my scooters a few times. Quality bearing at good prices and quick delivery.
As for CVT belts - I'm old school. Too important a part, so I stick with Kymco belts.
Kymco packaged belts from reputable suppliers.
Glad you're finding what you need.
« Reply #6 on: September 27, 2026, 11:22:07 AM »
Good sources for overseas! Txs for sharing!
BANDO and MITSUBOSHI belts are, as mentioned and IF original, KYMCOs OEM fitters in this segment.
Belts which are 1/2 or 1/3 of OEM priced stock are 99% fake, despite goodlooking OEM numbers printed on them, and wear out prematurely.
ATHENA, a spanish rooted producer distributes high quality rollers, brake pads and other stuff for our scoots.
ALIEXPRESS et al are not bad per se, but its always a potluck what you get, does not make a huge difference if you need an O-ring for a faucet, engine parts are more sensitive.
Bearings : japanese and austrian companies like SKF produce items which are way enough for a wheelbearing and accompanying oilseals.
This companies produce standart bearings with a tolerence of P0 - P6 which is nearly overengineered for a scoot.
Oilseals: two lipped products are preferable, which is not always to be seen on internet offers, though inexpensive.
« Last Edit: September 27, 2026, 05:57:50 PM by Ruffus »
