Author Topic: $6.659 most I've ever paid for a gallon of gas  (Read 1159 times)
« on: May 12, 2026, 09:50:26 PM »
Topped up at BP in Yellow Springs this morning.
I'm never going to complain about the price to fill up this Liberty150i - it sips fuel.
But did note this figure on the pump!
A highwater mark for me - and it probably will go higher.
Re: $6.659 most I've ever paid for a gallon of gas
« Reply #1 on: May 16, 2026, 11:15:34 AM »
Prices seem to have stabilised a bit here in the UK Stig, but then I have been out in the Yorkshire Boonies for a coupla weeks!
« Reply #2 on: May 20, 2026, 08:11:53 PM »
fwiw, I'm paying $17/gal for my chainsaw fuel   $85/5gal VP 50:1 premix (I've seen some places advertise $150/5gal)
not really gasoline though, primarily naphtha (94 octane rating) and proprietary 2 stroke oil
if I were using my saw regularly, I'd use pump gas, VP guarantees the fuel fresh in a container 5 years unopened, 2 years after opening. I used to throw away bad fuel quite often before I made the switch
« Reply #3 on: May 20, 2026, 08:28:45 PM »
wow, when you put it that way...I'm also paying about $26 USD / gallon for my 2 stroke premix. But my 2 stroke machines always start right up and give me no carb trouble. Plus I maybe go through a gallon each year.
« Reply #4 on: May 20, 2026, 08:48:17 PM »
not sure which brand of premix you're getting, most of those "gallon sized" containers are no longer 128 fluid ounces, they are only 110
my local Kymco dealer, is also a VP dealer, I think their regular price on 5 gal of 50:1 is $100, I get a 15% discount, hence $85
« Reply #5 on: May 21, 2026, 01:16:08 PM »
Randy, I buy the Tru Fuel red quart cans in the 50:1 mix. I think they're around $6.50 each..maybe a bit higher.  I also have a 'gallon' of the 4 stroke Tru Fuel that is 96 (?) ounces. I think I bought that to run through my generator when I exercise it occasionally and for the first fill of my 2 stage snowblower.
« Reply #6 on: May 21, 2026, 04:53:02 PM »
I've seen that brand at Lowes &Tractor Supply, cheaper than the Husqvarna brand
a gallon is 128 fluid ounces, I bet that "gallon" can you have is 110 oz
only 2 stroke I have are 4  Husqvarna chainsaws, the 395xp is a gas pig when I'm milling with it, a whole tank of gas + refill before I finish a slab cut
I also have a Ryobi ER160 2 stroke rotary hammer, but it's 25:1
