Author Topic: Cant believe it but more problems in just a week.  (Read 11904 times)
GoVanGo
« on: June 10, 2023, 06:22:49 AM »
So about 2 weeks ago I had the no power uphill or full throttle issue where some of you
all hit it in the head with fuel filter.
I put in new fuel filter and some lighter rollers and iridium spark plug and now the
scoot was scooting.    I got to ride it about 4 days and so yesterday was out in our valley and hilly area
( Bay area calif) and damn if I wasnt thinking to myself this thing is running great!  I was going uphills and on the flats and it was great.    And about 5 min and 3 miles from thinking that I came to a stop sign and it died.   WTH?  Ok waited a few minutes and got it going again came to next stop sign and it dies.    Now Im just thinking I need to get home with this thing.    Hit another red light and dies again.
Now once I got it running from dieing and kept the throttle high it was running find , not like any lack of fuel.     But then the 3rd stop it wasnt coming back at all.    Had to wait half hour , got it running and now I was just keeping it about 1/4 throttle and using brake to hold it back, ran red lights and stop signs and got it home.
Ok so today , did a valve adjustment intake was loose ,  but when it starts now it does this.
1.  Starts with high revs .
2. I can hear 1 misfire , then another then the revs slow down and then it dies.
3. I see a brown smoke cloud that comes out of exhaust
I did a carb clean 2 weeks ago , and it was running great with my carb clean ( I have never done a carb clean in my life on anything) .   Im not a mechanic just doing youtube vids.
Where do I want to go next?   Remember fuel isnt an issue if I keep the trottle wide open or above 1/4 open.
I ordered a new CDI,  new ignition coil.   What else would I want to look at?
Its a 2014 with 10k miles.
« Last Edit: June 10, 2023, 06:34:44 AM by GoVanGo »
06 ZX50
14 Agility 125
17  Like 200i
Before scoot life .
Honda XR100, 4 CB 750s , 1978 Kawa Z1R , 79 Goldwing , HD RoadKing , Honda Areo 1100 .
Vision
Re: Cant believe it but more problems in just a week.
« Reply #1 on: June 10, 2023, 11:27:27 AM »
I'm guessing it needs a new CDI (go OEM), that's what mine needed in the thread below.
Is it possible the wrong tolerances were used on the valve job?
https://www.kymcoforum.com/index.php?topic=30018.msg209662#msg209662
GoVanGo
« Reply #2 on: June 10, 2023, 12:47:05 PM »
Hoping the fix will be that simple .   No go with any DC chinese amazon cdi?
I did the valve job after the dieing at stop signs but will double check again later today.
I only had to adjust the intake .   I used .004 .
Thanks
06 ZX50
14 Agility 125
17  Like 200i
Before scoot life .
« Reply #3 on: June 10, 2023, 02:21:35 PM »
@GoVanGo, before you go into CDI business, take out your carb again and repeat cleaning.
Sometimes it takes several tries until a carb is neatly functioning and the scoot running.
Your scoot ran after cleaning, so should the culprit be there somewhere.
Brown/ blackish smoke means too much fuel or too less air (if misfiring too).
Also renew sparkplug, cable and cap. Its inexpensive and gives some peace of mind. Even you had a new Iridium plug,  does not mean it cannot be faulty.
Valve clearance: after you did, once again a full circle to TDC , clearance check, one more full circle to TDC....
« Last Edit: June 11, 2023, 09:36:43 AM by Ruffus »
Vision
« Reply #4 on: June 10, 2023, 03:53:23 PM »
I would only use an amazon cdi in a pinch and not for the long haul- but many still do. I've learned OEM is almost always best.
I use aftermarket brake pads/fluid and the only tires you should be using are Michelin City Grips. Once your reliability issues are over I can't stress enough that you should swap the OEM tires out and use City Grips (which is considered the best scooter tire) or a better grade of tire.
GoVanGo
« Reply #5 on: June 10, 2023, 07:47:22 PM »
i read about city grips here when I first joined and I instantly got them :)
06 ZX50
14 Agility 125
17  Like 200i
Before scoot life .
« Reply #6 on: June 11, 2023, 07:26:27 AM »
Good choice!
« Reply #7 on: June 11, 2023, 09:40:11 AM »
Well, I'm inclined to think that, brakefluid and tyres don't make a huge difference in this case.😉
« Last Edit: June 11, 2023, 12:53:15 PM by Ruffus »
« Reply #8 on: June 11, 2023, 12:29:45 PM »
lol
sparko
« Reply #9 on: June 11, 2023, 02:21:56 PM »
my first agility had fuel tank issues. I loosened up the cap just enough to let tank pressure equalize. It may not be your problem but something easy to check. seemed to only happen when hot.
GoVanGo
« Reply #10 on: June 11, 2023, 02:31:51 PM »
Yes i have this issue with my 50cc ZX ,  but on this 125 its only dying at low idle,  when I get going on it (full trottle) its was running fine .    Today I plan on doing another carb cleaning and also have some parts coming in today Sunday.
06 ZX50
14 Agility 125
17  Like 200i
Before scoot life .
sparko
« Reply #11 on: June 11, 2023, 02:57:05 PM »
maybe  clean tank completely so filter or line doesn't get clogged. or maybe vacuum line is clogged. bypass all the petcock and filter to see if anything amiss.
GoVanGo
« Reply #12 on: June 12, 2023, 03:12:01 AM »
So today did another carb clean , idle jet was a little dirty , so I was thinking aha this is it.   Double checked
my valve clearance , it was fine,
Put everything back together and same problem  .    Fires up , idles fast then some backfiring then dies.
If I fire it up and keep the throttle going then its fine.   So basically dies at idle after some backfiring.
I also have the idle screw as high as possible , doesnt fix it
Waiting on new CDI still , will try that next seems others had good luck with changing that out.
« Last Edit: June 12, 2023, 03:17:42 AM by GoVanGo »
06 ZX50
14 Agility 125
17  Like 200i
Before scoot life .
« Reply #13 on: June 12, 2023, 01:47:38 PM »
Just to be sure: has your idle screw o-ring and washer (pls see pic)
And: is your bystarter working properly, means new O-ring and gasket?
One more thing came in my mind:
-the valve needle within your carb tends to wear out on top, means, if this little washerlike piece is below one millimeter, could cause such behaviour.
« Last Edit: June 12, 2023, 06:02:17 PM by Ruffus »
GoVanGo
« Reply #14 on: June 13, 2023, 12:09:58 AM »
will have to check next time I take it apart thanks.
06 ZX50
14 Agility 125
17  Like 200i
Before scoot life .
