Author Topic: Cant believe it but more problems in just a week.  (Read 11922 times)
GoVanGo
Re: Cant believe it but more problems in just a week.
« Reply #15 on: June 13, 2023, 04:10:03 AM »
Just to be sure: has your idle screw o-ring and washer (pls see pic)
And: is your bystarter working properly, means new O-ring and gasket?
One more thing came in my mind:
-the valve needle within your carb tends to wear out on top, means, if this little washerlike piece is below one millimeter, could cause such behaviour.
Ok what is this black hole next to the brass colored part?  Is there supposed to be a screw there?
I have nothing there just the hole.   Is that where the dang idle mixture screw is supposed to be , is this the problem all along it fell out?  lol if thats what it is
06 ZX50
14 Agility 125
17  Like 200i
Before scoot life .
Honda XR100, 4 CB 750s , 1978 Kawa Z1R , 79 Goldwing , HD RoadKing , Honda Areo 1100 .
GoVanGo
« Reply #16 on: June 13, 2023, 04:12:14 AM »
my other post didnt go thru.   What is this hole next to brass color metal is that where a mixture screw i supposed to be???? There is nothing , is this the problem the screw fell out when I was riding?
If so dang LOL
06 ZX50
14 Agility 125
17  Like 200i
Before scoot life .
sparko
« Reply #17 on: June 13, 2023, 02:00:01 PM »
not sure but probably been off for 10k miles.
I would check a parts diagram. if the fuel petcock system diaphragm has a hole or tear in it the vacuum system wont pull fuel out of tank. I don't even know if this bike has one as I have never needed to look. happened on 2 other bikes i had. easy check. seems like a fuel issue tho. or a carb problem. or a vacuum problem.
« Reply #18 on: June 13, 2023, 04:57:01 PM »
hard to see the orientation on the carb...is the hole on the top side? If so, sure looks like and air fuel mixture screw hole...
« Reply #19 on: June 13, 2023, 05:33:03 PM »
Here is your other tread.
https://www.kymcoforum.com/index.php?topic=33452.msg234964#msg234964
Q: do you have somewhere on your carb a idle screw which looks like the one pictured by me?
See link
https://www.kymcoforum.com/index.php?topic=33440.msg234944#msg234944
If NO, likelyhood you lost it from this hole, is high
If YES, we have to search further
« Last Edit: June 13, 2023, 05:34:42 PM by Ruffus »
GoVanGo
« Reply #20 on: June 14, 2023, 03:21:30 AM »
See link
Well these sure run better with mixture screws in place.   Yep it was missing and yep thats why it was dying at idle.     Glad you posted that pic, made me look for my mixture screw and thats how I
noticed that hole with nothing in it.   Oddly when I cleaned the carb I never saw this screw , even in the first cleaning and I certainly didnt have any parts leftover and I used a magnetic tray to hold everything.   So I went back and looked at my first images and I can see that the hole was filled but not with a screw but like some epoxy stuff.   So crazy  but got a screw in there now and its back to running without dying.    Thanks again
06 ZX50
14 Agility 125
17  Like 200i
Before scoot life .
« Reply #21 on: June 14, 2023, 08:34:50 AM »
..on the other hand, from tech point of view, interesting. The very old AMAL  carbs didn't have an idle screw either. One regulated idle with pre- or late ignition.
« Last Edit: June 14, 2023, 01:45:00 PM by Ruffus »
« Reply #22 on: June 14, 2023, 01:22:58 PM »
added to list of possibilities as to why scoot is running poorly...missing idle air fuel mixture screw! Crazy! Previous owner just filled screw hole instead of just replacing screw?...Nuts..
