Author Topic: Venox timing  (Read 2129 times)
Jay
Venox timing
« on: April 19, 2013, 04:29:08 PM »
Hi guys
I need the correct marks that the cams need to be on for top dead center to be correct.
Please help the manual isuseless.
max oradea
Re: Venox timing
« Reply #1 on: April 20, 2013, 09:04:58 AM »
there are 2 reference you can look at.
1st the peak hole on the fly wheel cover on the left of the bike, and once the t1 and t2 come into view check the diameter lines on the camshaft sprockets to be horizontal. the factory setting is not too far off, so if you have to adjust a lot that means you might be on the wrong cycle. hope this helps a little.
