Author Topic: People GT 300i Questions  (Read 6142 times)
Scoota
« on: September 27, 2012, 02:10:00 AM »
Where can a person find the recommended maintenance schedule for the 300i?
Are the brakes non-ABS?  I didn't see anything stated on Kymco's site (maybe I missed it?)
Seriously considering one, rode one recently and liked it.
KentonLynne
Re: People GT 300i Questions
« Reply #1 on: September 27, 2012, 05:22:14 AM »
The maintenance schedule is in the owner's manual which you can download at http://www.kymcousa.com/owners/index.html
Basically regular maintenance is required at 1000km, then 5000km and then every 5000km after that.
The brakes on the People GT 300i are NOT ABS.
Scoota
« Reply #2 on: September 27, 2012, 11:40:45 AM »
Thanks for the info.
Another question, is there a way to bypass the side stand safety switch?
fshfindr
« Reply #3 on: September 27, 2012, 03:48:16 PM »
TRY PUTTING A FUSE IN THE EMPTY FUSE SLOT IN THE FUSEBOX.
Richard L. in Bellmawr
KentonLynne
« Reply #4 on: October 01, 2012, 05:21:17 AM »
Why in the world would you want to do this?   That feature has saved me a couple of times from riding off with the kickstand down and a possible spill.
Scoota
« Reply #5 on: October 01, 2012, 11:26:19 AM »
Maybe it's not for you to do, but as an experienced motorcyclist, I have not had an issue with sidestands and riding off with them down, guess I've developed a good habit of putting it up prior to riding off.
The reason why I would like to do it is because I'm a believer of not just starting the engine and riding off.  My normal routine is push the bike out of the garage and fire it up while I close the door and put on my helmet & gloves.  This allows for the engine to warm up and I don't need to just sit there.
I did the by-pass on my previous scooter, an Xciting 500 & had no problems.
Scoota
« Reply #6 on: October 02, 2012, 09:03:27 PM »
I found the fuse box next to the battery, is there a trick to get the cover off?  I'll have to check it out in more detail.
« Last Edit: November 23, 2012, 01:22:28 PM by Scoota »
Scoota
« Reply #7 on: November 23, 2012, 01:25:45 PM »
After removing the cover to the fuse box, there is one empty slot, but it doesn't have any metal contacts in it so the idea of putting a fuse in there to disable the sidestand switch is out.
What is this "thing" in the second picture for/what does it do?
MotoRandy123
  • Lets Ride!
« Reply #8 on: November 23, 2012, 06:10:36 PM »
That's probably the diagnostic port.
mrmike
  • Syracuse, NY
« Reply #9 on: November 23, 2012, 07:43:07 PM »
I've seen articles on ABS equipped GT300I's, but they are either prototypes or just available overseas.
