Author Topic: acceleraton lag  (Read 3014 times)
davisX500
acceleraton lag
« on: July 22, 2012, 04:55:29 PM »
Yesterday I took out my 250 scooter 8). Everything seemed fine for the first three miles I drove (which is a gravel road) then once i got to the black top she would only do about 50 mph :'( i kept up this speed while toying with the throttle and all at once boom she kicked in and i was doing 90mph :o yes i said 90mph :o. so i thought addjust the throttle cable which was loose as i found out but didnt solve the problem. any ideas? ??? i was told check the accelerator pump but have no idea how to know if its bad ???. well it seems to kick in as soon as i hit 50 mph on the dot. I am soooo lost.
« Last Edit: July 22, 2012, 09:14:32 PM by davisX500 »
davisX500
Re: acceleraton lag
« Reply #1 on: July 22, 2012, 10:39:26 PM »
since I have posted this I have (changed the oil adjusted the slack out of the thottle cable and looked at the accelerator pump as I dont know much about it it does seem to function properly.) all of these have helped but not resolved the problem. ??? :'( :'( :'( :'(
ce
Re: acceleraton lag
« Reply #2 on: July 23, 2012, 12:45:30 AM »
check the vacuum diaphragm in the top of the carb imay have a holeand it won't lift the slide all the way up.
Look at the exploded diagram at stadium yamaha, a Kymco parts supplier.
Albuquerque, New Mexico
BigOrange
Re: acceleraton lag
« Reply #3 on: July 27, 2012, 07:55:00 AM »
I had the same problem.  What CE said! It is the diaphragm and the piston mechanism in the carburator .
I wish I could ride more and drive less!
2009 Xciting 500i White!
2007 Xciting 250 Orange!
