Author Topic: Givi V46 Box Mount to Xciting 500Ri  (Read 11377 times)
htcneil2
Re: Givi V46 Box Mount to Xciting 500Ri
« Reply #15 on: May 19, 2012, 01:53:45 PM »
Yeah i saw them. Mine is a 2009. How is your different. Got a pic?
vex
« Reply #16 on: May 19, 2012, 10:38:58 PM »
I installed the SR89 kit on my '09. I had trouble getting any information from anyone about which kit was actually required. It took me about an hour or so. The most difficult part was getting the upper shock mount bolts out (I used two combination wrenches). Just make sure to do one side at a time, or else the chassis will drop and you'll have a heck of a time getting everything back up into its proper place. I didn't bother to try and torque the shock mount bolts, I just cranked them down tight. Let me know if you have any questions and I'll try to help.
« Last Edit: May 19, 2012, 10:44:19 PM by vex »
Syl
« Reply #17 on: May 19, 2012, 11:34:23 PM »
vex, I am sort of at a stand-still with my box project at this time and as you defined, it is the connection to the upper shock mount. I will feel much better if I take it to my service department being on the 2012 the inner saddle cannot be removed to see the shock mounts, That is the difference I attempted to explain to htcneil2 plus a couple install areas. The steel bottom plate shows to be mounted using spacers and they do not show how to attach them. Further, the two bolts under the black rubber cap if removed, will any of that back-end drop out of set-up and create difficulty there also? In other words vex, the whole set-up diagram and parts procedure are terrible. Another problem taking it to service will create...if they mount the rods and the plate is not yet installed, possible the rods should not be tightened yet until other part are in place to tighten all at once. I couldn't get in there to tighten those upper shock bolts. Appreciate the input on all this and hope will hear from GIVI.
htcneil2
« Reply #18 on: May 20, 2012, 12:01:43 PM »
By inner saddle do you mean the black tub?
Syl
« Reply #19 on: May 20, 2012, 01:51:58 PM »
Yes, on the 2012 the entire tub/inner saddle has to come out to show the shocks.....no way.
htcneil2
« Reply #20 on: May 20, 2012, 02:15:48 PM »
Why cant you remove it?
Syl
« Reply #21 on: May 20, 2012, 07:46:49 PM »
Everything is connected to it! I mean it is one solid unit from back to front of the scooter. no way.
htcneil2
« Reply #22 on: May 20, 2012, 08:24:09 PM »
All you need to do is:
10mm socket for i believe 5 including the ones for the hydrsulic seat. And four allen bolts by the seat latch. Then you can lift it up and dosconnecy the light and the power outlet. No electrical engineering required.
Try it. I mean you ought to get some tools  so you can do it and other things
Syl
« Reply #23 on: May 20, 2012, 10:52:53 PM »
htcneil2, thanks again for hanging in there with me. I just don't want to screw anything up by doing all that being the scooter is new. I just got to 195 miles on it today and want to get enough easy miles on it to be able to ride along with the big ride coming on for the homeless vets. I went there for 3 years not but never had anything big enough to keep up on the big road ways. I will look over that inside the seat cover again!
htcneil2
« Reply #24 on: May 21, 2012, 12:29:04 AM »
Its easy to take the inside tub out. The hard part is getting the connecting rods put in. Do one at a time.
Syl
« Reply #25 on: May 22, 2012, 09:11:25 PM »
Had the rods installed yesterday and they did a very neat job...better than what I could have accomplished. I will install the rest of it and hopefully all the parts I need have been included in the shipment. It cost me $56.00 and I feel it was worth it.
Syl
« Reply #26 on: May 23, 2012, 04:12:29 PM »
I installed the V46 today and as expected all the parts including wrong ones were in the kit from GIVI. Good thing I had the spacers from the installation on my 300 being the ones with the kit were too long. I am disappointed in GIVI being I wrote to them and hear nothing. I'll get some photo's as soon as I can get out one day between the rain drops. I ordered the rack and brake light assembly from revzilla and waiting for the reflective paint samples I sent for.
Cortez
    • My flickr account
« Reply #27 on: May 23, 2012, 04:48:02 PM »
Fame got to their heads.. and they're really nothing special.
Never were.
'08 FZ6n S2 ABS
Syl
« Reply #28 on: May 25, 2012, 04:09:26 PM »
First pix of the GIVI mounted on the X500Ri
Syl
« Reply #29 on: May 25, 2012, 09:35:22 PM »
Another GIVI Box view
