Author Topic: Putting it back together  (Read 57 times)
DryFly
« on: Today at 02:26:40 AM »
I pulled the CV assembly, cleaned everything up, installed new Dr pully sliders and got ready to install the new belt and… I’m stumped. You tube shows guys opening the drive face and movable driven face apart by compressing the movable driven face with their hands, installing the belt, then installing the belt on the variator assembly with plenty of slack. I’m no longer young by any stretch and I’ve lost some strength in my hands, but I cannot get that spring to budge. The result is that the belt rides up at the top of the V. The service manual is not real clear on this, but it seems to suggest looping the belt over the clutch and then putting the belt over the drive pully collar, then simply putting the drive pully face on and tightening the whole thing up. My assumption would be that the belt is forced into position when the assembly is tightened. Is this correct, or is there a better way?
200 7Kymco People 250
18,000 kms
« Last Edit: Today at 02:32:32 AM by DryFly »
Re: Putting it back together
« Reply #1 on: Today at 10:10:54 AM »
Fly, there is an easy way to compress the counterspring.
Take (pls see pic) a medium size C-clamp and compress this spring
 (clutch mounted and belt on clutch)
towards you to let the belt slip towards clutch center and give you enough belt lenght and slack to pull it forward and over the drivepulleys groove (crankshaft/boss).
Remove C-clamp!!
Then tighten the 17/19mm nut to 80KN, check once again visual overall.
Start engine to idle.
All fine?
Put CVT cover on it.
Not doing so results in pic #2, which is basically not disastrous but additional work/money.
« Last Edit: Today at 10:23:43 AM by Ruffus »
