Hi,
So I've been having this problem I guess for awhile, but I never noticed it until now. This has been happening for 2 years. Next to my fill nut on my transmission, a black powder keeps forming. I have included photos. If you wipe it off with a paper towel, it just flakes off. I'm assuming this is the transmission oil.
I didn't think much of it, until there was a heavy smell of transmission oil after a ride one day. I went to loosen the nut, and I noticed that it is no longer tightened. The nut remains in but it has maybe a cm of give. If i twist it left, it will not unscrew unless I twist left while pulling. Then I am able to remove the nut. When I turn right to tighten, the nut just keeps spinning.
How difficult is this repair? And what would you recommend I do? I feel like I've lost a lot of transmission oil the past 2-3 years riding along not even noticing this has happened. How much would a repair like this cost at a shop? Should I drain my transmission oil, and refill it in order to drive to a shop?
Thank you,
