Author Topic: Should sitt a screw here?  (Read 1641 times)
tvniklas
  • Passed the golden age 40...
« on: June 08, 2026, 07:18:51 PM »
I was drivning to work today and noticed louder sound from the exhaust than normal.
Air and Noice is coming from the middle hole in the front heat protection, where there are three stainless screws
What is suppose to be there?
Tried to post a Pic, but I possible from phone
Kymco Downtown 300i ABS -2013
ODO: 9950km
Dr Pulley 15g / Orginal rollers  (change all the time)
Gas average 0,29L/10km
Kymco Like 125  -2016  -Sold
Kymco Agility 50 -2015 -Sold
I have 14g ,15g and 15,5 Pulley´s to sell
Re: Should sitt a screw here?
« Reply #1 on: June 08, 2026, 09:29:45 PM »
To be clear - there are three screws - but one is missing?
tvniklas
« Reply #2 on: June 08, 2026, 09:42:14 PM »
Yes, i think it should be a screw in the middle hole.
I upload ed a Pic here : https://ibb.co/8DtDkTTd
ODO: 9950km
« Reply #3 on: June 08, 2026, 10:04:48 PM »
Can you "FEEL" pressure from this hole?
I wonder if that is a place to fasten a testing device?
If you can feel that the exhaust is open here, please see your dealer for the missing screw.
tvniklas
« Reply #4 on: June 09, 2026, 05:04:17 AM »
Oh yes Stig, i feel pressure and fumes are coming out of there
ODO: 9950km
« Reply #5 on: June 09, 2026, 12:37:03 PM »
.This a spot where a technician puts a sensor/ feeler gauge to check your NOX values.
In your case there were a "blind" plug, which you most probably lost.
Then go for an inox imbus/headbolt in that size.
Pls see.pic,
 -take RH bolt out (the one which holds heatshield)
- try in the middle to plug this hole
- go to a shop
- buy smtg similar
-put an alu washer or two under this plug
Don't worry, nothing bad happens
« Last Edit: June 09, 2026, 12:59:09 PM by Ruffus »
tvniklas
« Reply #6 on: June 10, 2026, 06:47:47 AM »
Pls see.pic,
- go to a shop
- buy smtg similar
Thanks 👍
I went to mechanic guy at work who gave an shorts M6 Bolt wita a Cooper washer, seems to work fine 😊
But now i see that my old bike needs new screws and Rubber around all exhaust system 🙃
https://www.motor-x.com/oem/c17121v-downtown-300i-2011-2016-299cc-4t
ODO: 9950km
« Reply #7 on: June 10, 2026, 10:10:02 AM »
Knew it works, good to see, most parts there on your muffler system are generic. Just look around to avoid OEM pharmacy prices.
