Author Topic: Idle RPM  (Read 829 times)
mrmike
  • Syracuse, NY
Idle RPM
« on: June 02, 2026, 07:38:31 PM »
   Finally got my scoot out for a ride today. Haven't paid much attention, but today I noticed that it idles about 2000 RPM. Is that the normal idle? If this is higher than normal, could it be because of the Dr. Pulley 11.5 gr sliders I have instead of the stock 13gr rollers? Where should I reset the idle if necessary?
Re: Idle RPM
« Reply #1 on: June 02, 2026, 11:23:51 PM »
Pretty sure your scoot is EFI, no carb - it uses an electronic fuel management system and the idle is factory set.
Stock idle speed is probably @1800 +/- 100 RPM like my EFI'd LIKE200i.
I'm pretty sure the idle speed is not affected by the roller weights.
Maybe she just needs an Eye-Talian Tune Up!
Ride it a bit more at speed and see what happens!
« Last Edit: June 03, 2026, 06:46:25 AM by Stig / Major Tom »
