Author Topic: Shorted something after changing bulb. No power on 2023 like 150i  (Read 1254 times)
Moliemook13
Hello, I pulled out a directional bulb to check for size and after inserting it back in, I turned the ignition on and Heard a little pop sound and lost all power. I checked the two fuses on The battery underneath the seat and the 25 and 10 amp fuses are fine. What could have happened? Are there any other fuses and where are they? Could something else have shorted out? Any help would be appreciated.
Re: Shorted something after changing bulb. No power on 2023 like 150i
« Reply #1 on: April 17, 2026, 11:39:48 AM »
Welcome here!
Pls check your owners manual first, about where and how many fuses are installed.
Don't know your 2023 model exactely, but there should be two glass inline fuses under your floorboard (middletunnel, if still mounted at modelyear 2023).
Mentioned 25 and 10 amps fuses read a lil bit to high for light circuits.
Maybe there (floorboard) is the culprit.
« Last Edit: April 17, 2026, 12:55:55 PM by Ruffus »
