Author Topic: cambio candela comodo  (Read 2028 times)
amoleasia
« on: March 07, 2026, 06:39:01 PM »
 a vostro avviso e, possibile sul kymco 500 r dopo aver smontato la sella e, il vano sottocaschi posto al disotto di essa, accedere diciamo abbastanza agevolmente alla candela di accensione, per sostituirla, grazie
Re: cambio candela comodo
« Reply #1 on: March 07, 2026, 08:40:02 PM »
No, has to be removed from the middle access hatch with KYMCOs original sparkplug pipe socket, which is under the scoots seat.
To have straight access ratch up rear wheel a bit towards seat.
« Last Edit: March 08, 2026, 12:59:40 PM by Ruffus »
amoleasia
« Reply #2 on: March 08, 2026, 11:31:35 AM »
quindi, se metto la moto sul cavalletto centrale e, poi sollevo la gomma posteriore questo fa ruotare e abbassare  il motore,e a tuo avviso rende piu facice l accesso alla candela , attraverso lo sportellino posto sul tunnel centrale,esatto
« Reply #3 on: March 08, 2026, 01:15:44 PM »
Exactely so. Watch out for proper reseating of sparkplugcap. Give it outside a good smear of silicone grease, otherwise you get a hard to find ignition issue.
« Last Edit: March 08, 2026, 01:17:46 PM by Ruffus »
