Scooters - Big Bore
Xciting 500
leaking drops from water pump
Topic: leaking drops from water pump (Read 2335 times)
amoleasia
Newbie
February 02, 2026, 12:01:33 PM »
and for some time I have seen some drops of coolant leaking from under the cooling water pump. In your opinion what could this depend on? Thanks
Re: leaking drops from water pump
February 02, 2026, 12:32:04 PM »
Most probably ceramic seal faulty, same procedure on 500 than on 150. (pls see link)
BUT before you start working on the pump check all three (3) hoseclamps and close by hoses for tight seat or demage. Also drainplugs seal should be seen.
https://www.kymcoforum.com/index.php?topic=33849.msg237425#msg237425
Last Edit: February 02, 2026, 01:26:34 PM by Ruffus
Scooters - Big Bore
Xciting 500
