Author Topic: Poor ride with new tyres, any thoughts?  (Read 18495 times)
gt alex
« on: August 20, 2025, 07:53:04 PM »
 I recently had new tyres fitted front and rear, and ever since at speeds 20-40 kph on smooth roads the front jumps around like I'm riding over cobble stones then smooths as speed increases.
I went to a local shop for the tyres and it was not a good experience, so I don't want to go back.
I don't know whats wrong but I'm thinking the forks are binding, so the plan is to loosen the axle bounce the bike and re-tighten it.
I would like ideas other owners may have?
Thanks and stay safe.
Re: Poor ride with new tyres, any thoughts?
« Reply #1 on: August 22, 2025, 01:13:24 PM »
Was your front wheel dynamically balanced after tire change?
Are your wheel bearings in good order?
Were your wheel/s properly remounted?
What kind of tires you bought?
All this effects.
gt alex
« Reply #2 on: August 23, 2025, 08:05:25 AM »
All this effects.
Thank you. I really don't think they balanced the wheels. At low speed it feels like the forks aren't moving. They are Dunlop standard size.
I worry about the mounting but it looks ok, I think I will remove a and refit the front. They work on expensive bikes and I think they just didn't care about mine, they even due a large arrow on the rims with a paint pen direction of rotation.
Wiz
« Reply #3 on: August 25, 2025, 04:23:55 PM »
Way back when I had my People 150 I used Dyna Beads to balance the tires and they worked very well for me.
https://innovativebalancing.com/motorcycle.htm
Current Rides: Can-Am Ryker Rally 900cc, Gold 2012 People GTI 300.
gt alex
« Reply #4 on: April 11, 2026, 08:53:35 AM »
It turned out the problem was my fault. After fitting lower rear shocks the bike was too upright when the kick stand was down, so I increased the front preload to raise the bike a little and it was too much causing the front to skip.
Backed the preload to almost standard and it rides well.
« Reply #5 on: April 11, 2026, 07:54:05 PM »
Thanks a lot for your update!
Enjoy your bike!
