Author Topic: 300i Xtownm replaced breaks and Speed and Odometer no longer working. Any hints?  (Read 1053 times)
Batman-NYC
I replaced the front and rear brakes and tires, then the Speedometer and Odometer stopped functioning. Any idea what could have happened in this basic replacement?
Welcome here in this hive!
You replaced yourself brakes and tires or let replace it?
In case you let, pls see the workshop and tell them.
You did it by yourself: control main suspect first =
- check speedometer cable attached with cableties to your RH front brake hose (might be broken or unplugged during front brake job)
- METIN box out and check fuses close to battery
- check cable connectors within underseat area
- see all connectors in your front area
- check function of brake switches L&R
- check function of your KILL switch
Pls see all this and come back for Qs.
« Last Edit: August 11, 2025, 07:13:53 PM by Ruffus »
