Author Topic: 500R fuel pump  (Read 17057 times)
wymple
500R fuel pump
« on: July 11, 2025, 08:31:20 PM »
I had my fuel pump go out several years ago on my fuel injected 2010. I bought one off the net from Italy, and it would not pump enough pressure to meet the minimum requirement, which I think is 45 lbs.  So I gave up & paid the bill to have a dealer in Iowa City get one from Kymco. They had zero communication, no idea when it would show up or where it was at. It took about 6 weeks.  I hated that. Does anybody have a reliable source for one?
Re: 500R fuel pump
« Reply #1 on: July 12, 2025, 12:34:58 PM »
This is where I usually buy fuel pumps
.amazon.it , they are inexpensive, fit perfectely and work without flaws..
2.7 - 3.0 bar are enough when you test it by using starter motor only, no running or revving..
..with idling motor and bypass tester between 3.0 and 3.5 bar..
Pls see pics....
« Last Edit: July 12, 2025, 12:52:19 PM by Ruffus »
wymple
Re: 500R fuel pump
« Reply #2 on: July 12, 2025, 04:45:45 PM »
Wonderful..!! Thank you very much..!!
wymple
Re: 500R fuel pump
« Reply #3 on: July 12, 2025, 09:46:31 PM »
So I searched for a couple of hours, & I'm not getting results.  I get currently unavailable, does not ship to the United States, or overlapping years that can't be correct.  Some say 2007-2013 or 2014. They are not the same. None of them list the operating pressures.  Do you have a more direct link to one that fits a 2010 and pumps over 3 bars?
Re: 500R fuel pump
« Reply #4 on: July 13, 2025, 09:34:51 AM »
Well,  checked up on my source here in Italy, they have it available, though non of them lists operating pressure rate. Easy to check with a manometer.
Fuel pumps same year for XC 250, XC 300 and XC 500 are ident.
Yours is a 2010 and falls into 2009 - 2013 even I didn't see a different one on other year models.
wymple
Re: 500R fuel pump
« Reply #5 on: July 14, 2025, 03:12:31 PM »
Yeah, that's strange as I see quite a few ads for the XC300. I should be good to go then. Thank you.
