Author Topic: 50cc suspension upgrade/overhaul  (Read 2860 times)
Scootsuper9
« on: June 17, 2025, 03:06:54 PM »
Looking for generic advice (I have a super 9 which almost everything is discontinued for because they don’t really exist anymore.
Looking for suspension advice, definitely need an overhaul. I can get fork seals but the the front fork springs are discontinued. Do you think it is fine to reuse? Or should I potentially try and run a set from a super 8? (Can check the travel), and recommendations for fork oil?
For the rear monoshock, I figured a measure and swap would be fine (full monoshock) by just measuring and finding a replacement and adjusting to suit needs.
Any help is appreciated, figured at least someone has overhauled 50cc suspension before. Honestly all the forks look nearly identical, I wouldn’t be surprised if springs were the same
