Author Topic: This is look bad?  (Read 10307 times)
Yoni159
This is look bad?
« on: May 19, 2025, 07:59:52 AM »
How to clean it? I used wet napkins it help a little.. brake cleaner will clean it?
https://files.fm/u/7k6n39wh36
Re: This is look bad?
« Reply #1 on: May 19, 2025, 12:32:56 PM »
I've used a toothbrush and soapy water to clean calipers and pistons. You can also use some very fine steel wool to clean the pistons. You don't want to push dirty, corroded pistons back into the bore. I would be very careful using brake cleaner as it will cause rubber parts to swell, although I don't see the rubber dust boots visible in your picture (?)
« Reply #2 on: May 20, 2025, 09:46:16 AM »
Pistons in this condition have to be renewe, for they do NOT garantee a safe brake system anymore.
Yoni159
« Reply #3 on: May 21, 2025, 02:46:34 PM »
why renew? I can just clean them with brake cleaner.. they still work
« Reply #4 on: May 21, 2025, 08:25:57 PM »
Because brakes and parts of it are safety related items on which yours and others lives depends on.
