Author Topic: Final drive belt adjustment for AK550  (Read 11131 times)
Hornblower
« on: April 05, 2025, 08:13:19 PM »
I didn't see any info about this in the owner's manual. Since the belt is not centered in the rear wheel pulley, I want to attempt to adjust this. I assume I can simply do this by adjusting the tensioning bolts but I need to know how much tension there should be in the belt. Anybody have info on this?
big blue
Re: Final drive belt adjustment for AK550
« Reply #1 on: April 06, 2025, 11:29:32 PM »
I found this video on the rear drive adjustment, I hope it is what you need...https://www.youtube.com/watch?v=Hsjlz5qMkd4
  • Central Iowa
« Reply #2 on: April 08, 2025, 03:02:34 PM »
As for centering the belt...
I find that my belt refuses to stay in the very center. My current adjustment is the best that it's been since I've owned the AK. My belt has been very consistently 2-3 mm from the outer rim of the rear sprocket since the last time I replaced the rear tire. Up until that time, for the first 2.5 years The belt was often drifting from outside to inside on the sprocket. The important thing to know is that the belt must be set to be a minimum of 1 mm from either rim of the rear sprocket. I haven't looked for a while but I was sure the Owner manual states that. I do have the service manual downloaded and it gives a detailed explanation of how to adjust and where the belt should sit. As long as the belt doesn't touch the rim on either side. 1 mm is about the thickness of a standard (flat) screw driver blade, usually. Here's a series of photos for when I adjusted the belt adjusters.
https://photos.app.goo.gl/Kf1x6Dw1tC51mwHg6
Aside from the video in the post above there are many videos for adjusting the belt on many motorcycles with a belt final drive. Almost all are the same procedure.
The manuals for the AK show using a sonic tension meter to adjust the proper belt tension. I'm not spending the high cost just for one device that I will only use for one thing on the rare occasion that I would need to use it. I decided to follow the method used by Harley Davidson owners for their belt final drive bikes. I bought a belt tension tool from Amazon. I found the center point between the front and rear sprockets and use the tool on that point along the belt. When I first bought the AK I checked the tension to get a starting point for what tension is needed. I found that pushing up on the bottom run of the belt along the mid-point with the tool the deflection needs to be between 3/8 and 7/16 inch at 10 lbs force. Here are a few pics and a short video how I check this.
https://photos.app.goo.gl/25dydWo8FZ2szXS17
Here is a link to the tool I bought.
https://a.co/d/3XKu9S3
If tension is too tight, meaning more force needed for 3/8 inch deflection, then the belt needs to be loosened just a very little bit. If tension is not enough, meaning more than 7/16 inch deflection at 10 lbs force, then the belt needs to be tighter. This is the part that takes patience and time... usually. Have the axle nut making full contact but not tight. Not loose either but just so the axle plates can slide. Check alignment and tension again after tightening the axel nut to torque spec.
I cut a slot in the inner bottom belt cover that my tension gauge fits into to allow me to hold the gauge straight up. Another owner who followed my lead on this and posted a YouTube video on it actually removed the belt holder on the gauge and put a hole in that inner cover rather than a slot. I felt the belt holder was needed to avoid damage to the belt.
Hornblower
« Reply #3 on: April 08, 2025, 07:04:26 PM »
Thanks, Bob! This is great info! I had previously bought one of those belt deflection measuring tools but couldn't figure out how to use it. I actually tried checking tension with a guitar tuner but didn't have any luck. Somewhere, I had seen to tune for 110 hz but that wasn't specifically for the AK550. So, basically, I remove the lower belt cover, find the center of the belt, and look for 3/8" deflection at 10 lbsf. Getting that right and keeping the belt in the center of the rear pulley could require some patience.
  • Central Iowa
« Reply #4 on: April 10, 2025, 01:42:45 AM »
YEP!
Quick-Star24
« Reply #5 on: June 01, 2025, 04:52:54 PM »
You will not get the belt in the center and have it stay there. You just need to see a tine bit of space between the belt and the pulley rim. It just will not line up with the middle of the pulley no matter how many hours you work to get it there. Film yourself setting it and prove me wrong! I would love to get it centered by this boy has not been able to get it there and keep it there. Good Luck!
  • Central Iowa
« Reply #6 on: June 02, 2025, 11:54:15 PM »
AS I mentioned in my post 2 above. The best you can do is to ensure the belt stays at least 1 mm away from the inner and/or outer edge of the sprocket.
nushipwright
« Reply #7 on: July 10, 2025, 04:28:04 PM »
While reading through the service manual I've found this:
18.8mm +/-0.5mm
This may come handy if nether the overpriced sonic tool nor the spring loaded gauge are available.
"Sometimes I wonder whether the world is being run by smart people who are putting us on or by imbeciles who really mean it."  - Mark Twain
Hornblower
« Reply #8 on: July 10, 2025, 07:10:52 PM »
18.8mm +/-0.5mm
That might get you in the ballpark with a new belt but I doubt it's very useful as the belt stretches. The cheap belt deflection tool mentioned previously is what I've decided to use.
  • Central Iowa
« Reply #9 on: July 10, 2025, 11:36:14 PM »
18.8mm +/-0.5mm
What he said...
That is provided only as a STARTING point to get you close. I found that doesn't even get the belt evenly adjusted on the rear sprocket at all. Do that adjustment and then readjust A LOT as needed to finish properly aligning and putting the right tension on the belt.
