Author Topic: Help me start my downtown  (Read 22540 times)
vale
« on: March 13, 2025, 08:52:06 PM »
I have a 300DT. A month ago, because the weather was announced to be a little bit bad, I thought that is a good idea to put the battery on charger for 1-2 days when outside it was snow. The snow passed, I put the battery on, the bike started from the first key. Get my kid to school, come back to go to work with the bike, it didn't want to start again.
I don't know much about technicalities so my guess was that the battery was in a bad condition. I bought a new one, the same result. I did some reading, checked the stand sensor, check for spark (it was present), still no go. The brake levers are working (confirmed by the stop light).
I bought a new spark (the other one had 3 years of usage) the bike does the same.
This is where 'the internet' is not helpful.
Maybe somebody has a new idea.
I uploaded a short video here: https://streamable.com/9z5lll
PS: yes I know that I can take it to a mechanic but that means a good amount of money that I wished to invest in the bike (evacuation and windshield)
Thank you!
Re: Help me start my downtown
« Reply #1 on: March 13, 2025, 09:32:40 PM »
Spark is there, confirmed?
Jumpstart from a car battery, car idling!
If it starts then, battery shot.
If NO, then it might not get fuel.
Is the plug wet or completely dry after sstart attempts?
« Last Edit: March 13, 2025, 09:36:17 PM by Ruffus »
vale
« Reply #2 on: March 13, 2025, 09:50:24 PM »
I tested the old spark, it was present. For the new one O didn't test, thinking that it is new...
This picture I took with the old spark after a few attempts of starting.
« Reply #3 on: March 14, 2025, 01:34:35 PM »
Ok, plug looks wet = fuel is there
Please try with a NEW sparkplug, NO throttle and jumpstart from a car.
vale
« Reply #4 on: March 14, 2025, 03:42:09 PM »
Will do, first i need to find a neighbor with car and cables :)
Let's presume it will start, what then?
« Reply #5 on: March 14, 2025, 04:52:04 PM »
It will indicate a tired battery. Time for a new one!
vale
« Reply #6 on: March 14, 2025, 05:56:12 PM »
well, as I stated in the first message, this behavior is present on the old battery but also on a NEW one installed.
« Reply #7 on: March 15, 2025, 08:57:14 AM »
Ok,
-BOTH brake switches work?
-killswitch on RUN
-sidestand UP
-sparkplug cap tight on plug?
-battery connectors  tightened and in good condition
-fuses out, clean, check and spray smtg on
-ground cable to starter motor OK?
Put a direct jumpcable from battery MINUS to engine block (anywhere).
Do not rely on the fact the battery /sparkplug are new and therefore proper.
NO throttle, START
Do a thorough engine wash and drying to get rid of all the dirt there.
« Last Edit: March 15, 2025, 01:19:03 PM by Ruffus »
« Reply #8 on: March 15, 2025, 12:42:31 PM »
My mistake Vale, an easy go to given how sensitive to battery voltage that our eFI Kymco engines are!
« Last Edit: March 17, 2025, 05:32:44 PM by Neil955i »
vale
« Reply #9 on: March 15, 2025, 08:56:17 PM »
Quote
can you help me with the location of this cable?
« Reply #10 on: March 16, 2025, 05:03:13 PM »
Looking straight down close where the starter motor dissapears in the engines block, there is a 6mm bolt which holds a clamp connector/cable to the block.
(pls see pic) its a 300 XC but yours is the same
« Last Edit: March 16, 2025, 06:43:59 PM by Ruffus »
vale
« Reply #11 on: March 16, 2025, 10:06:54 PM »
Quote
check and done
Quote
Yes, the connection seems very sturdy.
Tomorrow I will try to put some more fuel into it, the most expensive that I can find, to rule out also this possibility.
« Reply #12 on: March 17, 2025, 11:23:45 AM »
Fresh fuel,
-crank without sparkplug a few times
-sparkplug in
-jumpstart cables from idling car
-no throttle
-START
vale
« Reply #13 on: April 16, 2025, 12:34:37 PM »
An update on my problem.
The only thing that i didn't do was to use jumcables from a car. because lack of cables and car :)
The thing that I did, with an advice from a friend, was to keep the starter button pressed more that 1-2 seconds. And after a few rounds of 7-10 seconds, at some point it STARTED!
This was two weeks ago. Since then, no problem at all, started fine even after a few days of unused.
I still don't know the cause, I will think that was gunk in the fuel.....
Now that the problem was resolved, advice me on how to protect those wires and electrical connections, because I want to clean that area (you see how dirty it is around there :( )
« Reply #14 on: April 16, 2025, 08:53:07 PM »
Take this bolt out with an 8mm spanner,
- use a little bit of fuel and a brush to clean this area
- sand or scratch the connector clean
- use grease after your rebolted this connector again.
- maybe avoid smoking or an open flame close by
