Author Topic: Disconnected engine oil pressure cap..  (Read 6977 times)
Yoni159
« on: February 06, 2025, 12:59:08 PM »
https://ibb.co/Q7nvhy6H
This is bad? I cant put it inside again its not working... When i switch on the scooter i must have red oil light but now i dont have it? This will harm my scooter?
Re: Disconnected engine oil pressure cap..
« Reply #1 on: February 06, 2025, 03:10:39 PM »
No harm to be expected at alI IF your scoot wasn't faulty before.
Just bend contacts together a bit, replug, and its good again.
Cable should be ABOVE exhaust pipe, fix it with a cabletie.
« Last Edit: February 06, 2025, 07:35:11 PM by Ruffus »
Yoni159
« Reply #2 on: February 06, 2025, 06:29:36 PM »
No harm to be ecpected at alI IF your scoot wasn't faulty before.
its still not working i still dont have red oil light on the dashboard.. what the purpose of this oil pressure sensor?
« Reply #3 on: February 06, 2025, 07:41:34 PM »
Reason for this switch is do indicate enough oil pressure within your engine to lubricate all neccessary turning parts like bearings, crank etc.
Ignition on = oil pressure light ON
Off after a few seconds.
Oil light permanent ON = to less pressure and NO lubrication.
No light can be:
-faulty oil pressure switch (pretty rare)
-cable lose or broken (by exhaust pipe?) suspected
-cable shoe corroded
-faulty fuse
Pls go through all of this.
If all fails, take the pressure switch out, go to a motorcicle dealer (they can benchtest it) and buy smtg similar with the same PSI stamped on it.
« Last Edit: February 06, 2025, 07:53:05 PM by Ruffus »
Yoni159
« Reply #4 on: February 06, 2025, 08:01:07 PM »
No light can be:
-faulty fuse
if i would ride without this switch working it will cause damage?
« Reply #5 on: February 06, 2025, 10:02:12 PM »
Not at all, but IF your engine suffers an oil issue, you will not notice it and destroy it, which might be more costly than a €20,- switch.
Yoni159
« Reply #6 on: February 07, 2025, 02:49:14 PM »
so the purpose of this oil pressure sensor is ONLY warning you if something fail? Thats it?
« Reply #7 on: February 07, 2025, 04:50:17 PM »
Bingo! In some countries also a legal requirement  (from a certain year on) to have specific engine information like CHECK ENGINE, BATTERYCHARGE, NEUTRAL, INDICATORS, etc. on your dash.
« Last Edit: February 07, 2025, 08:39:51 PM by Ruffus »
