Author Topic: agility 125 front brake master cylinder  (Read 10888 times)
Re: agility 125 front brake master cylinder
« Reply #15 on: June 01, 2023, 09:32:38 PM »
Sorry to see H4 doesn't fit. Europe models seem to have H4 or HS1 version, depending on year or country.
« Last Edit: June 01, 2023, 09:37:03 PM by Ruffus »
sparko
« Reply #16 on: June 11, 2023, 02:30:23 PM »
new setup. I can use both oem lighting and when on back roads by myself flip on the off road light. 500 percent or more light. I know it looks like hell but who cares. just cut out a section of front plastic. there is a small bracket enough to mount a frame for lighting. I may eventually find a legal light to install but it is safe to ride when on a dark road at night. plus I can reach down with left hand and adjust it high or low quite easily. I connected directly to battery through a handlebar switch. I have a 200 cca battery installed as well on bike as oem is lame and part of the problem.
sorry about the earlier ranting. this was such an easy fix and I get so upset with being sold something that is blatantly crap that I forget how much effort is put into the rest of the bike, which is top notch. fix your lighting now people and show some photos so others can feel empowered. It cost about 25 dollars to vastly improve the light setup.
« Last Edit: June 11, 2023, 02:53:42 PM by sparko »
sparko
« Reply #17 on: July 14, 2023, 02:06:21 PM »
BA20D
that looks like the right bulb designation. found this for 12 bucks amazon will get next week and let everyone know immediately if its better than oem which wasn't safe. But with the add on offroad light that I put on the lighting setup is very safe and allows me to travel at night. It is hard to put into words how much better good lighting helps at night. With this new bulb coming in I hope only have to use the off road light as a backup but honestly have not had any drivers flashing their lights at me when using it. I have only used it pointing down so they are not directly affected by 15 degree light spread. I will let everyone know how this new bulb works.
https://www.amazon.com/dp/B096VJ3VJ4?pd_rd_i=B096VJ3VJ4&pf_rd_p=6cfa532e-9c8f-48d2-87a3-a61547a0d356&pf_rd_r=H01T166HVCX5PQBR83C7&pd_rd_wg=zplRJ&pd_rd_w=UCGtl&pd_rd_r=d94f25f5-c760-4a57-9e95-1476501a4289
sparko
« Reply #18 on: July 20, 2023, 03:26:12 PM »
new bulb much better but needs more light pointed to center of road. high beam still focused too high down the road so useless. will try another soon and report back.  :-\
