Author Topic: 200i Electrical Problem Headlight Voltage Drop  (Read 2261 times)
-kp-
« on: February 17, 2022, 02:26:10 AM »
Greetings,
I picked up a 2013 Like 200i project that is rough n ready, however it has an electrical gremlin.  I'm stuck!!! Usually I can grind these issues out but not this time.  Here is what I know:
-With the headlight unplugged the scooter starts no problem.  New battery 230cca bigger battery upgrade.
-With the headlight plugged in the voltage drops to 10.5v (full 12.6 at the battery).
-I unplugged every light, relay, horn, bar switches, main harnesses to search for the voltage to return to the headlight and nothing.
-Tested the ground, 12.6+v from positive battery terminal to chassis/horn...all is good, no voltage drop.
-checked chassis grund and starter ground, all is good, nice and tight no corrosion.
The wiring diagram shows a kick stand switch but I can't find it.  (I have the cyclopedia manual)
CELP goes from solid red to 3 flashes during fuel pressurizing then blinks twice (low voltage..makes sense)
-tried a different bulb (higher watt) and the same issue.
-initialized the scooter just because
What am I missing?
« Last Edit: February 17, 2022, 02:33:55 AM by -kp- »
Re: 200i Electrical Problem Headlight Voltage Drop
« Reply #1 on: February 17, 2022, 09:08:59 AM »
The LIKE200i does not have a kick stand lockout (,in spite of what owners manual says)
There is a tip over lock out.
4AM here, let me think about it after I find some coffee!
« Last Edit: February 17, 2022, 10:09:32 AM by Stig / Major Tom »
« Reply #2 on: February 17, 2022, 09:12:43 AM »
 oh yeah...
welcome to the forum!
Major Tom
« Reply #3 on: February 17, 2022, 10:54:16 AM »
@-kp-, welcome here.
Had an interesting issue with one of my LIKEs.
Pls see link,
maybe helps. In this case the ground cable was internally destroyed by corrosion.
Another culprit might be one of your handlbar switches (corrosion). RH switch intiates LH switch via relay.
https://www.kymcoforum.com/index.php?topic=31637.0
LIKEs have, like most of our motorcycles pretty thin cables, pls check your charging socket within glove compartement and around relais for corrosion.
« Last Edit: February 17, 2022, 11:09:16 AM by Ruffus »
-kp-
« Reply #4 on: February 17, 2022, 03:10:11 PM »
Thank you both for the information.  I ordered a dimmer switch, the ohm readings were a bit erratic.  The drain is on the positive circuit so it seems like a good place to start.  I'll repost back if it fixed it.
-kp-
-kp-
« Reply #5 on: February 22, 2022, 01:03:32 AM »
Killed by the kill switch.  It tested fine, but would fail under load.  Switch shortages can be a pain.  Grounding issues are so much easier to find and diagnose.
An embarrassing amount of time was spent, but it's fixed now so that's worth a 🍺
« Reply #6 on: February 22, 2022, 11:22:42 AM »
Happy to see you found out!!
« Reply #7 on: February 22, 2022, 01:21:35 PM »
glad you fixed it..and thanks for coming back to report your solution.
« Reply #8 on: February 22, 2022, 02:34:34 PM »
Absolutely 💯 👍!
As my old 1st Sgt used to say , "That's one in a row!"
