Author Topic: Yellow Code light  (Read 2624 times)
TD2593
Yellow Code light
« on: July 05, 2019, 09:10:19 PM »
While sitting at a red light today the yellow engine code light came on and stayed lit. Scooter is a 2012 500i ABS. Running fine, temp good cant seem to find an issue. Pulled into a gas station, turned the scooter off and fired it back up light is off and has not been back on since. The bike has 4200 miles on the clock and runs great. What is needed to run the codes and where is the port ? Thanks
Re: Yellow Code light
« Reply #1 on: July 05, 2019, 10:24:19 PM »
Kymco analyzer tool and I know what the connector looks like but have no idea where it is. Does that model have EFI?
Lord Faversham
  • Upper Class Twit of the Year
  • Farkhem Hall, Tittering, Middle England
« Reply #2 on: July 06, 2019, 02:55:38 PM »
Having had mine to bits recently, it would seem that the port for the OBD reader is found on the RHS underneath the seat glove box. It’s right by the RHS seat lock. Whether you’ll be able to get at it without taking off the seat and glove box/helmet locker inner is another thing mind you.
HTH
Faversham.
Regards
Faversham
Farkhem Hall, Tittering, Middle England.
https://www.youtube.com/watch?v=J1FfrnOXGHg
Current Wheels:
Kymco Xciting 500i
Honda CX500
Yamaha R125
Previous:
BMW RT1100
Honda RD03 Africa Twin 750
Kawasaki GPZ500s
Derbi Terra Adventure 125
Countless Lambrettas
Lord Faversham
« Reply #3 on: July 06, 2019, 03:12:30 PM »
Here you go:
Place the scooter on its main stand and put the side stand up prior to using the diagnostic tool.
Remove the two battery cover screws with a #2 Phillips screwdriver. Remove the battery cover.
The diagnostic plug is located to the right of the battery. (I guess this depends on which direction you’re facing!)
Plug in the tool to the ECU connector and turn on the ignition switch to send power to the tool.
It’s as I said previously, on the RHS of the bike by the RH seat lock.
HTH
Faversham
Regards
Faversham
Current Wheels:
Kymco Xciting 500i
Honda CX500
Yamaha R125
Previous:
BMW RT1100
Kawasaki GPZ500s
TD2593
« Reply #4 on: July 07, 2019, 01:59:24 AM »
Thanks guys ! Where can a fellow obtain the OBD scanner for the Kmyco ?
Lord Faversham
Regards
Faversham
Current Wheels:
Kymco Xciting 500i
Honda CX500
Yamaha R125
Previous:
BMW RT1100
Kawasaki GPZ500s
