Author Topic: Brake lever safety switch  (Read 3786 times)
pipster326
« on: July 22, 2018, 12:09:39 AM »
The DT300 is not starting when I pull in the left brake lever. Does anyone know the part number,for that part? Anyone else ever have to replace one? TIA
kneeslider
Re: Brake lever safety switch
« Reply #1 on: July 22, 2018, 01:24:43 AM »
Yeah. The brake switch is dead. Ebay have the part cheap. Make sure you get the left side switch.
Easy fix.
Sent from my HUAWEI VNS-L31 using Tapatalk
2019 Yamaha X-Max 250
kneeslider
« Reply #2 on: July 22, 2018, 01:27:18 AM »
Sorry forgot to tell you how to change it.
1) look under the left lever cluster, you should see that little black switch.
2) undo the Phillip screw and the switch will come out.
3) unplug the two blade connectors
4) bin that old switch
5) do the reverse to reinstall the new switch
mousejunks
« Reply #3 on: July 22, 2018, 01:30:39 AM »
If you need a quick fix, you can spray the switch with lots of contact cleaner then WD40. This may solve the issue for a while until you get the replacement part.
A non-working brakelight switch is a safety issue.
'09 Kymco Espresso 150i
'17 Kymco Downtown 350i ABS
pipster326
« Reply #4 on: July 22, 2018, 09:50:36 AM »
Thanks kneeslider and mousejunks. I appreciate the help
Rich
stuo
« Reply #5 on: August 07, 2018, 12:10:00 AM »
Another fix: you can use a thin knife blade, pop open the switch, burnish the contacts with 400 grit, spray them with contact cleaner, reassemble...then replace the brake bulb with an LED to reduce the current through the brake switches. Both my switches crapped out, it's a common problem on the DT. I must credit mjr (Mike the Master) with this fix.
2009 GV 250
kymcogrampa
« Reply #6 on: August 08, 2018, 11:05:30 PM »
Great info! Thank you and mjr.
Rene
Scooters = great smiles per gallon.
