Author Topic: how to tighten mirrors on a 300 downtown  (Read 6238 times)
intrepid004
« on: July 17, 2018, 07:38:50 PM »
how do you tighten the mirrors on a 2014 300 downtown
Re: how to tighten mirrors on a 300 downtown
« Reply #1 on: July 17, 2018, 08:54:12 PM »
Well, there are two "tighteners" on DT mirrors. Which one? 1. Where mirror assembly screws into the handlebar, or 2. The pivot after the assembly is mounted.
intrepid004
« Reply #2 on: July 17, 2018, 09:43:43 PM »
where the mirror attaches to the handlebar.
i can see that there are nuts but it looks like you would need a very thin walled socket to get it in there.
ScooterWolf
« Reply #3 on: July 17, 2018, 09:44:53 PM »
Don't physically twist the entire mirror assemble around to try and tighten it. You'll end up snapping the wires that run under the upper sleeve that power the turn signal. If they do snap it's easy to fix, but better to leave them undisturbed.
- Wolf
« Reply #4 on: July 17, 2018, 10:19:49 PM »
What Wolf said as a very important precaution. Don't even think socket on this one! That nut takes a 17 mm open-end wrench. Be vewy, vewy careful not to damage wires!
EvilTessmacher
« Reply #5 on: July 18, 2018, 01:48:12 AM »
The way I did it on my X400i was this: I carefully disconnected the turn signal plugs from each other, and then screwed the mirror stalk into the handlebar socket. Then, I tightened down the locking nut with a 17mm open-end wrench to the point that it was snug, but not overtight. Then I reconnected the plugs. There is also another locking nut at the top of the stem where the stalk goes into the mirror housing. That one is hell the ruggedest mile to get adjusted, because it takes two hands to hold the mirror housing from moving while you're snugging up the nut. I only have two hands, so I enlisted my lovely spouse to hold the housing while I did the locking nut.
Two things to consider...
2018 Kymco 400i - "Diana"
2013 Honda PCX - "Natasha"
1982 Honda PA-50
« Reply #6 on: July 18, 2018, 01:07:14 PM »
ET's procedure is best. Do it that way.
