Author Topic: AGILITY 50 twin....  (Read 5032 times)
ORBITZ
AGILITY 50 twin....
« on: May 19, 2010, 03:15:13 PM »
....it aint a twin cylinder agility if youre wondering...hehehe ...its a Sym Orbit :P
Im new here, I live in Portugal and I ride a Sym Orbit 50 4stroke, and its the same as the agility.
i´m havin some kind of a trouble with mine...
Mods.
Airsal 50mm cylinder
gay racing red fan....
Leovince scoot exhaust
polini variator
and...
24mm carb...
kn filter
conclusion: mounted the 24mm carb and each time I try to accelarate it goes dead,  dont know what seems to be the prob...
too much air?
small head intake ?
Jetting?
All the best
Bruno
Re: AGILITY 50 twin....
« Reply #1 on: May 19, 2010, 06:19:03 PM »
...Welcome to th' Forum Orbitz...
..i just installed a 20mm carb on my A50, and immediately had to up-size the main jet..
..came with a "95" and i'm now at a 101...
..i'd suspect you would need to increase your jet size also..
..then do some plug chops to fine tune the fuel mix...
..i'd love to hear more about this 24mm carb as you go along...
peace
« Reply #2 on: May 19, 2010, 07:39:45 PM »
My thought is there may not be enough vacuum to run the 24mm. Can you get it to rev at all? does it run at ANY throttle position? (1/4 throttle,1/2 throttle, 3/4) Slinger may be right on the jetting, and these ?'s will help figure it out.
« Reply #3 on: May 19, 2010, 08:39:22 PM »
...wow z, hadn't thought of that...
..but with a 50mm cylinder, wouldn't that increase the vacuum?
« Reply #4 on: May 19, 2010, 11:38:56 PM »
Depends on the head/pipe...It may have great compression, but squat for vacuum.
« Reply #5 on: May 19, 2010, 11:40:03 PM »
...gotta suck and blow...
..i see.....
ORBITZ
« Reply #6 on: May 20, 2010, 02:57:29 PM »
Hi m8s!
The airsal kit runs with stock head, and has a lot of compression... it will only start by kickstarter... the electric start doesn´t have enough strenght...lol
I can rev it only 1\4 of throttle, anything more than that it will choke... :P
The carb came with a 105 gigluer, and I thought it would be plug and go....big mistake hehehehe
I have already ordered 2 jet kits and a machined spacer for the intake, to try to solve the diffrence in diameters ;)
« Reply #7 on: May 20, 2010, 11:20:50 PM »
I was going to ask how it was adapted. Can you hook a vacuum gauge to it at idle to get a reading? I would compare that reading to the # where it falls off, or just before to verify the carb can be used. If I went 2mm bigger my scoot won't even idle. My concern is the valve size on yours. A vacuum gauge is cheap, and will tell you everything there is to know on a 4t
« Reply #8 on: May 20, 2010, 11:30:20 PM »
..speaking of vacuum..i guess i've handled the tubing so much during my NUMEROUS rejettings, that i created a split in the hose, that i take loose to suck fuel back into my carb after re-assembly...
..found it a lil while ago...it was back where my fingers would be, as i grip the hose to remove it from the fitting..
..i'm going to install a cpl of 1/4" valves and a T, so i don't have to handle the main vacuum hoses any more...
« Reply #9 on: May 20, 2010, 11:52:52 PM »
Not a bad idea! That would make a good hook up point for a gauge as well.
« Reply #10 on: May 20, 2010, 11:56:39 PM »
...sure would wouldn't it....
 :D
ORBITZ
« Reply #11 on: June 17, 2010, 03:55:43 PM »
back again.... and pissed... ???
got my new jets, and the problem stays the same...
i tried from the 88 to 105 gig and wouldnt rev.
if i put my hand on the carb intake, when I tried to rev it, it throws gasoline back at my hand and chokes.
does the needle position have anything to do with this?
really pissed off...
now i´m thinking to swap it for a 19 or 20mm carb.... will it fit the original head intake?
the sound of the leovince exhaust is soooooo sweet!!!
cheers
bruno
« Reply #12 on: June 17, 2010, 11:01:11 PM »
The 20mm will fit. That is most likely the cure to your trouble. The 24mm will work w/ a 70cc or bigger jug kit. Its kinda like sucking thru a straw vs a paper towel tube. Your engine cannot create  enough vacuum to pull fuel thru the main jet.
ORBITZ
« Reply #13 on: June 18, 2010, 12:47:10 PM »
I´VE GOT IT!!!! ;D ;D ;D ;D ;D
The little orbit is pumpin gas on the 24 cvk hehehehe
I was thinking all wrong... it was way to lean. I raised the needle to the max and installed the 106gig.
throttle response is just brutal hehehe
now I want to adjust the clutch springs and then work my way to adjusting the carb.guess i will need to go to 108 or 110 main jet.
I´ve got an airsal 80cc.
my mom thought that went home with an atv lolol
way to loud 8)
« Reply #14 on: June 18, 2010, 01:07:18 PM »
Glad to see you got it sorted out!
