Author Topic: about the super 9 engine  (Read 2604 times)
pyro
« on: October 20, 2015, 05:05:19 AM »
Is the kymco super 9 engine a clone of the gy6 engine ?
Triesandluth
Re: about the super 9 engine
« Reply #1 on: October 20, 2015, 05:07:05 AM »
No.  Honda dio clone,  if I'm not mistaken.  No where near gy6,  except the variator
Triesandluth
« Reply #2 on: October 20, 2015, 05:08:09 AM »
But don't necessarily use one.  After tuning the engine the regular gy6 variator will fall apart
pyro
« Reply #3 on: October 20, 2015, 07:30:31 AM »
The reason I ask is I was looken at a stretch kit for a Honda ruckus and they have the gy6 engine I was curious if the super 9 has the same engine mounts
TheAmishSasquatch
« Reply #4 on: October 20, 2015, 06:17:30 PM »
If your going to build a custom stretched 9, why not make a custom stretched bracket? It's going to be so much less $ then buying a kit. Some tubing and plate and a welder is just about all you need ;)
Triesandluth
« Reply #5 on: October 20, 2015, 09:20:27 PM »
^^^^there ya go!
pyro
« Reply #6 on: October 23, 2015, 02:07:50 AM »
Could you explain a little more I've never done a stretch to anything
TheAmishSasquatch
« Reply #7 on: October 24, 2015, 02:10:47 PM »
There's a bracket that mounts your drive train to your frame. Depending on design, there is usually a long bolt that mounts te 2 together. Some bikes may vary. You simply buy another long mounting bold, and fabricate a bracket to go between the drive case and frame. The length of bracket determine the amount of stretch. You will have to relocate the rear shock so a bracket must be made there too.
pyro
« Reply #8 on: October 26, 2015, 04:07:42 PM »
Ok thank you that makes since
