Author Topic: Reeds from malossi bbk  (Read 3824 times)
Triesandluth
« on: June 25, 2015, 12:13:34 PM »
I believe I've read elsewhere that the reeds sent with the kit do not work for the super9. If I recall,  the reeds in the bike are larger than what they sent me.  These look tiny.  Anyone know?
Re: Reeds from malossi bbk
« Reply #1 on: June 25, 2015, 03:46:26 PM »
I just did a Malossi kit on a People 50 and the reeds it came with were too small for the People 50 block.
Triesandluth
« Reply #2 on: June 25, 2015, 04:20:31 PM »
Figured so.  The ones it came with look TINY!
Sent from my XT1080 using Tapatalk
TheAmishSasquatch
« Reply #3 on: June 25, 2015, 07:30:08 PM »
As soon as I seen the thread I knew the contents LOL.  My kit just came in and the reeds are way too narrow. I had the same issue with a set of CF reeds I purchased for the Super 9 from KD Air out of Germany. I will call Scooterparts Co. and see whats up.
« Last Edit: June 25, 2015, 07:33:47 PM by TheAmishSasquatch »
TheAmishSasquatch
« Reply #4 on: June 25, 2015, 07:35:21 PM »
Just called Scooter parts Co. and left a message as they are closed today.
« Reply #5 on: June 25, 2015, 11:47:31 PM »
They make zero difference. Most times they actually fail, and make issues.
I use blank CF stock to cut my own.
http://www.torqsoft.net/reed-petal-design.html
Triesandluth
« Reply #6 on: June 26, 2015, 01:03:36 AM »
I've heard that.  I've also heard that these stock ones are rather awesome and to use them until they quit
« Reply #7 on: June 26, 2015, 01:08:50 AM »
I think I have seen ONE failed stainless reed in 40+ years of building engines. Perhaps 50-100 failed fiberglass, and 25-30 failed CF reeds.
I think the best route is to punch a bunch of 3/16th holes in the stainless, and back the holes with 0.2mm CF reed blank to make a solid 2 stage reed.
That will provide much better low end, and retain the top rpms. I'll post up when I make mine in a few weeks.
Edit:
sandwich the stainless between two sheets of 1/8th in steel to prevent distorting the stainless. Clamp it tighter than F8ck...
« Last Edit: June 26, 2015, 01:10:43 AM by zombie »
Triesandluth
« Reply #8 on: June 26, 2015, 02:00:01 AM »
Definitely do share when you're done.
TheAmishSasquatch
« Reply #9 on: June 26, 2015, 12:27:45 PM »
Thanks for the link. Ive also thought about making my own but not sure of the thickness.  I think the PO installed aftermarket reeds. They dont feel like my DK Carbon fiber reeds, theyre black and feel like the malossi reeds but to be honest Im not sure the Malossi reeds Are CF, theyre opaque and no visible weave so I tend to think they and the reeds currently installed are fiberglass not carbonfiber.
« Reply #10 on: June 26, 2015, 03:21:01 PM »
The stock reeds in kimchi engines are black blastic
« Reply #11 on: June 26, 2015, 05:30:57 PM »
Squatch... Fiberglass. CF can not be mistaken, and is 100% non see thru.
Most reeds in these bikes are .4mm in CF, or .6mm in glass. Stainless is around .5-.6mm
B&L... I have to try making a set from Blastic. Where do you find this new, and exciting product? Is it on Amazon???
Is this something you stock??? I NEED some. Now I can't sleep!
TheAmishSasquatch
« Reply #12 on: June 26, 2015, 11:47:41 PM »
I'd post pics, but the forum protocol suck something horrible and no matter what I do it says the picture is too large. I would figure a forum/site with this size and volume would allow pics larger the 192kb.  Guess not :\
Triesandluth
« Reply #13 on: June 27, 2015, 12:51:29 AM »
I use an app on my phone called photo size reducer. Works great.
« Reply #14 on: June 27, 2015, 12:57:25 AM »
The last People 50 I did a Malossi 70cc had black plastic reeds, they were not carbon fiber but a solid black no carbon weaving at all. I have also taken a few Kymcos apart that have the normal metal reeds.
