Author Topic: Tire size on the 700 uxv  (Read 11161 times)
Wicked Al
Re: Tire size on the 700 uxv
« Reply #15 on: May 19, 2015, 03:07:43 PM »
Nice Work
Thanks! I have too much fun doing this stuff.
laidback
« Reply #16 on: May 19, 2015, 07:43:00 PM »
If we had that much hp in our 700's we would putting can-am's to shame. Lol
pndwv
« Reply #17 on: May 21, 2015, 02:09:32 PM »
No doubt on that how did you get that much Horsepower
Wicked Al
« Reply #18 on: May 21, 2015, 02:32:48 PM »
Suzuki SV1000 motor...stock. Didn't really feel a need to build it :)
laidback
« Reply #19 on: May 21, 2015, 02:45:42 PM »
Wicked al try putting a boss boss 502 in the uxv I don't think there is a need to build that motor either.   :D
Wicked Al
« Reply #20 on: May 21, 2015, 02:58:14 PM »
Hmmmmmmmm.....I'm a Hemi guy, Hellcat has a nice ring to it. Might have to relocate the seat. Speaking of mods, I discovered the Fiat 500 is about the same wheelbase as a UXV 700, that would make a fun body change.
laidback
« Reply #21 on: May 21, 2015, 03:21:47 PM »
Wicked al I misspelled that it's boss hoss 502 check it out on YouTube  :D
pndwv
« Reply #22 on: June 03, 2015, 06:33:48 PM »
Hey Alex what size wheels did you go with and what were the offsets Looks great to by the way keep up the good work
               Thanks,Paul
Wicked Al
« Reply #23 on: June 04, 2015, 04:58:22 AM »
Laidback, looked up the Boss Hoss, agreed, wouldn't have to modify that motor at all, might need a slightly larger fuel tank though.
Paul, The tires are on MSA M-21 Lok wheels. These are 14x7 with a zero offset.  http://cocomponents.com/dealer/m21-lok-utv-wheels-beadlock/
Because there is no offset, it will make the vehicle a few inches wider as the stock wheels have a positive offset. Because I also did the wider tires in the back, I stretched the bed another 6 inches wider to accommodate the tires so they would tuck into the fenders on full compression.
pndwv
« Reply #24 on: June 05, 2015, 06:14:53 PM »
Thanks for the info kinda don't want to make mine wider just wanting more ground clearance
              Paul
Wicked Al
« Reply #25 on: June 06, 2015, 04:05:29 AM »
I'm sure other manufactures have tables like this too, http://cocomponents.com/dealer/wheel-specs/ you can see which wheel has the right offset. I haven't measured the stock wheels so don't know what they are. Bolt pattern is 4 on 110.
pndwv
« Reply #26 on: June 08, 2015, 07:44:16 PM »
Thanks for the info
        Paul
JoeMarshall
« Reply #27 on: June 23, 2015, 11:43:32 PM »
So I had to check out the boss hoss 502. Interesting build. I was surprised when I watched the video when it raced the ninja zx12. Ninja wasted it, I thought with that motor it could keep up. :(
laidback
« Reply #28 on: June 24, 2015, 12:58:40 PM »
The boss boss weighs a lot  I think it's a little over 1,600 pounds.  :o
« Last Edit: June 24, 2015, 01:08:28 PM by laidback »
JoeMarshall
« Reply #29 on: June 24, 2015, 01:19:43 PM »
I doubt weight is the problem on that. lol. That's a lot of motor for that, he prolly can't hold it wide open. I just wanted to see it beat the ninja.
