Author Topic: Performance Ignition Coil upgrade  (Read 4650 times)
donatello
« on: April 10, 2015, 09:46:38 AM »
I am considering buying a performance ignition coil to improve spark but am curious to know if anyone has experienced better performance? or is it no better than a stock coil
Re: Performance Ignition Coil upgrade
« Reply #1 on: April 10, 2015, 03:18:27 PM »
You won't feel anything. Consider this, is a $20 "racing" coil better than the $50 OEM Kymco coil? No!!!! It's just orange!!!!
donatello
« Reply #2 on: April 14, 2015, 06:25:58 AM »
You make a valid point. Thanks for the advice! You just saved me $20  8)
MrXT
« Reply #3 on: April 14, 2015, 07:24:45 AM »
Well....the orange one is cheaper soooooo.......
Kymco agility city 125cc (2013)
4000km
« Reply #4 on: May 01, 2015, 01:00:17 PM »
My best $7 ignition improvement was to replace the stock NGK plug with an Iridium NGK spark plug.
This was on advice from several forum members.
No idea about power improvement - but it smoothed and steadied the idle considerably - most noticeable while sitting at a light in traffic when you DO NOT want to feel/hear any faltering in the idle!
Find the correct Iridium replacement for the stock NGK on NGK fitment chart.
jeeves
  • Dubrovnik, Croatia
« Reply #5 on: May 01, 2015, 07:49:04 PM »
Mine has been inside for 35000km, no problems. Took it out not that long ago just to see how it looks like.  A ok.
Iridium plugs should be good for at least 60000km [emoji6]
Agility City 125
Vision
« Reply #6 on: May 02, 2015, 02:48:55 AM »
Really?! I was going to change mine every 4k miles.
jeeves
« Reply #7 on: May 02, 2015, 09:04:45 AM »
That would be a waste of money.
I also have iridium plugs in my motorcycle. They have been inside for 55000km, no problems.
Took them out last week just to see how they look like, they are still good.
Iridium plugs last very long [emoji6]
Agility City 125
« Reply #8 on: May 02, 2015, 03:16:38 PM »
I've found it depends on how well the engine is ruining, if its rich it'll foul iridium plugs fast. But generally they last forever almost. Cars are rated at 100k these days with iridium.
FBR090375
« Reply #9 on: May 08, 2015, 09:39:03 PM »
what upgrades will make my 2014 agility 125  run faster more horse power???
« Reply #10 on: May 08, 2015, 10:28:20 PM »
Upgraded camshaft, free flowing exhaust, larger carb, 150cc cylinder kit, larger ported head etc etc. depends on how much you want to spend and what you want out of it. Also a lot of these mods should only be undertaken if you know a fair amount about working on engines, or else you'll end up with a screwed up 125.
