Author Topic: 2009 grand vista transmission fluid change  (Read 2896 times)
Boudroux
« on: August 18, 2014, 11:19:39 PM »
Need some advise here please.
It's time to change my gear/transmission fluid. What brand and weight are you using? I can tell by the manual how to get the fluid out, but how in the hell do you get the replacement fluid in? Please advise tool to accomplish this.. Thanks for walking mr through this. ;D 8)
nushipwright
Re: 2009 grand vista transmission fluid change
« Reply #1 on: August 19, 2014, 09:57:16 AM »
use a huge syringe to fill up. or a small funnel with a flexible extension plastic pipe....
"Sometimes I wonder whether the world is being run by smart people who are putting us on or by imbeciles who really mean it."  - Mark Twain
« Reply #2 on: August 19, 2014, 03:38:26 PM »
Get yourself a syringe that measures in cc, drain, then fill 230cc in the upper 12mm bolt. Best to drain after riding while it's warm and use 80w90 synthetic gear lube. A liter will last you years.
mi wii
« Reply #3 on: September 23, 2014, 04:42:37 AM »
I replace my gear oil every or every other engine oil change, which is every 1000, or 1500 miles depending on how the timing falls and availability to do so. I know it doesn't need it that often but it's an easy job to do.
