Author Topic: New Member - gas draining question.  (Read 9349 times)
airmanpogodayev
« on: April 23, 2014, 07:56:56 AM »
Hi, I have a '09 Venox that was not started in 12-16 months. I'm trying to get back up and running. While its hooked to ma car battery w/ jumper cables the motor turns and tries to start (i can hear it and feel the air coming out of the pipes).
I want to drain the gas, but I cant figure out how to. The "drain" tube on the let side of the bike right next to the tank does not drain anything. Can someone pls tell me where the fuel drain line is.
Thanks,
max oradea
Re: New Member - gas draining question.
« Reply #1 on: April 23, 2014, 09:09:27 AM »
hi! do you want to drain the fuel from the fuel tank or the carb bowls?
If the pilots are blocked then the bike should still start with the choke! i think...
To drain the fuel tank you will have to best take off the fuel tank to drain.
For the bowls there are one screw for each carb, located on the attached photo which i will post on later today! have a cloth ready to catch the fuel!
« Last Edit: April 23, 2014, 09:16:05 AM by max oradea »
max oradea
« Reply #2 on: April 23, 2014, 02:23:42 PM »
marked red is the bowl drain bolt for the right, the left is facing the left same position on the bowl. The blue is the idle speed screw, and the yellow ones are the idle mixture screw, set to 2 1/2 turns out!
« Reply #3 on: April 23, 2014, 02:46:25 PM »
It's easiest to plain old siphon the fuel from the tank.
You're gonna have to take the carbs apart for a complete cleaning.
The time spent doing that is much better spent than fighting it.
If you need help doing that just ask.
max oradea
« Reply #4 on: April 23, 2014, 09:12:54 PM »
agreed carb off job is a complete fix, specially if you are at the beginning of the season. or even half way, its worth the job. just have a vacuum gauge standing by when you are done because without balancing its just half the job with nearly 90% of the time.
Carb job is somewhat difficult the 1st time, then after that its just a matter of 30 min off and 40min back on with a 20min blow with compress air in between!
Good luck and we are here to help out!
Mike-the-Bike
« Reply #5 on: May 22, 2014, 10:02:59 PM »
The fuel petcock is vacuum operated; there is a rubber diaphragm inside that will stop gas flow when the engine is off.  Dis-connecting the fuel lines will not allow fuel to flow out of the petcock.  Syphoning will be difficult if your tank has the same interior design as mine (maybe a US thing?); a plate blocks access to running a hose into the tank--unless you have very flexible tubing (I didn't when I tried).  I removed the tank and stood it up on the front edges, removed the fuel petcock, and carefully poured gas out of the petcock hole into a container.
« Reply #6 on: May 22, 2014, 10:38:22 PM »
I just dump my fuel in the ocean. The Tide takes care of it for me. Same for oil, old paint, and the stuff left over from my Meth lab.
Gotta love Mother Ocean. She's one heck of a house keeper.
« Reply #7 on: August 06, 2014, 05:15:48 AM »
True...
z333
« Reply #8 on: November 24, 2014, 04:09:35 AM »
Christ, zombie. I know it's sarcasm but it still makes me twinge.
« Reply #9 on: November 24, 2014, 06:50:23 AM »
Me too... I just reread from the start of the thread, and kinda choked when I read that post.
My fingers do most of the posting. I just sit here laughing.
Disclaimer... I DON'T dump those things in the ocean. I dump them in my neighbors well. Outa sight, outa mind!
z333
« Reply #10 on: November 25, 2014, 01:52:44 AM »
Haa, yuss. And thanks to the pic in this thread, I found the answer to my thread! ^.^
« Reply #11 on: November 25, 2014, 02:38:34 AM »
Forums are the best part of the web. Well after Chinese monkey porn, and Silk Road.
Forums are the third best part of the web.
z333
« Reply #12 on: November 25, 2014, 07:11:56 AM »
I was under the impression Silk Road was closed down. Chinese monkey porn? That's a thing? Damn, and I thought adult babies and vore were wierd, and I was done lurking. Whelp, off to the races. "What has been seen cannot be unseen."
« Last Edit: November 25, 2014, 07:18:46 AM by z333 »
« Reply #13 on: November 25, 2014, 11:37:14 PM »
Silk roads back... It's existing members or invite only now.
Monkey porn I got from South Park.  https://www.youtube.com/watch?v=VnrIjzesTAk
