Author Topic: DT300i problem with abs  (Read 3388 times)
Sky__BastarD
« on: November 16, 2013, 03:32:57 PM »
hello from greece
i have 2.5 years that scooter, today a problem happend with abs and electronics, when i open the lights abs work fine but the km indicator doesnt work... abs lamp at speedometer its open also and check engine lamp.... when i turn off the lights doesnt work the ABS at brakes
that happend to anyone from you???
for the scooter i go for service only at kymco garage
de-dee
Re: DT300i problem with abs
« Reply #1 on: November 20, 2013, 05:01:51 AM »
in north america we do not have ABS  in kymco scooters so you will not get any info here , unless there is auto mech.s that can tell you about the system for cars,  go to BMW forum you cold get some info there, or honda,
mrimppis
« Reply #2 on: December 03, 2013, 08:32:36 AM »
Hello from Finland!
I had similar problem with my DT 300i ABS version. Speedometer was not working and ABS light was on.
Follow the speedometer cable starting at speedometer sensor, there's a connector at below lights and fork.
Mine had one of the two cables broken where the connector is.
Cable brokes easily in time.
8eeman77
  • Work hard, ride safe
  • I'm a scooter loving Apiarist
« Reply #3 on: December 03, 2013, 12:35:43 PM »
It could just be your battery needs replacing, a scooter battery needs most of its charge for the scooter to run correctly. Take it to your nearest mechanic for a service.
The Kymco DT 300i ABS is the best scooter you can get. I love it's carefree automatic ride. I would like to see kymco make a 600cc version but no heavier then the 300. I would buy it for sure
mrbios
  • 2005 Kymco Grandvista 250cc
    • My YouTube Channel
Re: DT300i problem with abs -- SOLVED / SOLUTION - Bad Regulator
« Reply #4 on: January 19, 2014, 08:56:20 PM »
I sent Sky__BastarD an email and he replied back that his regulator was bad and that caused to stator / alternator to put out the wrong voltage which caused the ABS to disable itself.  New regulator, correct voltage and everything is working fine.
PaulC
