Author Topic: PUZZLED HERE HEADLIGHTS.I THOUGHT BUTTTTTTTTT  (Read 4240 times)
feebleknievel
    • Kickin Country hITS
« on: October 22, 2013, 02:16:10 PM »
the littel bulb covers above the low beam headlights for some reason i thought they came on guess not so is it just for looks
mnpugdog
Re: PUZZLED HERE HEADLIGHTS.I THOUGHT BUTTTTTTTTT
« Reply #1 on: October 22, 2013, 02:25:28 PM »
Those are the non USA turn signals. You can go under the tupperware and reconnect them.
feebleknievel
« Reply #2 on: October 22, 2013, 03:28:52 PM »
when you say reconnect  them is it a matter of plugging tem in or the wires are not connected thanks
feebleknievel
« Reply #3 on: October 22, 2013, 04:33:38 PM »
okay got front cover off once you do it 1st time its not that bad to do..i found the wires to the lights above low beam you said they are the non us version of the blinker strange thing is the wires are wired into the low beam head lights not the blinker system so if i want to use them im gonna have to run wire  up to the blinker system is what your saying
feebleknievel
« Reply #4 on: October 22, 2013, 05:03:18 PM »
okay they are blinkers but where do i hook them up at .lol
de-dee
« Reply #5 on: October 22, 2013, 05:11:15 PM »
  I hooked mine up to the running lights, but some changed them to LED. lights and hooked them to the turn signal wires Im not sure where it is hooked up,. it could be at the blinker relays,
feebleknievel
« Reply #6 on: October 22, 2013, 05:12:38 PM »
do you know where the blinker relays are on this contraption  thanks De
de-dee
« Reply #7 on: October 22, 2013, 06:51:41 PM »
  If I remember they are on the right side just back of the horn,.
de-dee
« Reply #8 on: October 22, 2013, 06:55:10 PM »
  one of those black cubes should be the blinker,. ill have to look at the manual again,.
de-dee
« Reply #9 on: October 22, 2013, 07:21:48 PM »
  looking at the manual the blinker relay is just above and back of the horn, the next back is hi beam then low beam relays,.  I got this on page 106 section 19 on the manual
mnpugdog
« Reply #10 on: October 22, 2013, 07:23:13 PM »
Others have reported that Kymco just cut the wires and taped over them, so if you just reconnect them they should work. I have not opened it my self yet, but will this winter.
de-dee
« Reply #11 on: October 22, 2013, 07:43:08 PM »
  yes the wires are taped but to short to rewire to turn signals and do not show where to wire them,
feebleknievel
« Reply #12 on: October 22, 2013, 07:48:43 PM »
well on mine there put together midway of the low beam wires with a pinch connector so there actually wired into the low beam side not sure why maybe they had running lights there before i bought it n put the turn lights in i might get some regular bulbs and install them to see if that's what they did i should have taken a pic of them .but they are connected .but they are connected to the low beam wires who knows..im lost as hell so
de-dee
« Reply #13 on: October 22, 2013, 08:12:20 PM »
  on mine the lights were there but the hot wire was not wired in., just the ground wire,. so I made them running lights,
feebleknievel
« Reply #14 on: October 22, 2013, 08:14:56 PM »
mine has the yellow light bulbs so ill have to get clear ones to do running lights correct
