Author Topic: Won't crank has been setting more than 10 years.  (Read 61528 times)
JOB
Re: Won't crank has been setting more than 10 years.
« Reply #15 on: June 08, 2025, 11:25:52 PM »
Here's the only one so far.
JOB
« Reply #16 on: June 08, 2025, 11:29:11 PM »
Here is another.
« Reply #17 on: June 09, 2025, 06:41:40 PM »
Maybe that helps, wiring diagram for 125/150..
https://www.google.com/url?sa=t&source=web&rct=j&opi=89978449&url=https://kymco.at/pub/media/Download/Kymco/SPPeople125.pdf&ved=2ahUKEwi75sWh_uSNAxV2nf0HHWyWA-QQFnoECGIQAQ&usg=AOvVaw06o6KKqFc8m4CPfEM1WB-c
Since you have juice on certain strands with ignition on, looks to me like a fuse/fusetray failure. Have a close look at connectors which lead to fuses.
The minus wire which leads from battery minus to your motor block, corrodes off interally sometimes, see that too.
Further renew ALL  relays to eleminate any culprit.
« Last Edit: June 09, 2025, 06:53:38 PM by Ruffus »
JOB
« Reply #18 on: June 09, 2025, 11:12:37 PM »
Rufus, the fuses are new, the start relay is new, and the battery connections are good. I think the cdi is bad or there is a broken or defective wire. I appreciate your assistance. Jeff
« Reply #19 on: June 10, 2025, 07:48:24 AM »
You have voltage on your LH switches, right?
Horn, passing, LH brake light switch and so on.
Do you have juice on your RH handlebar switches, i.g. brake light switch, kill switch, hazard lights?
Again, all relays renew.
New battery or better jump cables from a car.
Ignition on, starter solenoid bridged with pliers, what does it do?
Motor cranks or no reaction at all?
JOB
« Reply #20 on: June 10, 2025, 08:26:26 PM »
Ruffus, I have brake light, kill switch, start button continuity and voltage. It's a new larger battery from my 650 Suzuki Boulevard. When I jump the start solenoid the starter turns her over just no spark. I have a new Fri coming.
« Reply #21 on: June 11, 2025, 12:13:48 PM »
Since you have all RH items checked and functioning...
Looks
like ignition coil or accompanying pieces as, cable, sparkplug cap, sparkplug, coz' CDIs are pretty stable on Kymcos scoots.
Have a look at this two thin cables towards ignition coil too. Corrosion and seat.
Cut off isolation from sparkplug cable, go direct on the sparkplug with this blank cable to avoid faulty cap.
(I had a faulty cable which shorted against the frame once, only seen in the dark)
Check all this before mounting the new CDI to make sure its the culprit.
One by one, not all at once. Note down each step.
« Last Edit: June 11, 2025, 12:26:41 PM by Ruffus »
JJJoseph
  • Kymco Sento 100
« Reply #22 on: June 13, 2025, 08:49:30 AM »
Some models have a side-stand lockout switch.  The starter doesn't activate if the side-stand is down, or if you're not holding a brake lever.
« Reply #23 on: June 14, 2025, 05:58:50 PM »
JJJoseph has a point!
What IF, this sidestand switch is engaged somehow??
JOB
« Reply #24 on: June 16, 2025, 04:09:53 AM »
I checked and there is no center or side stand safety switch. I'm not getting power to the ignition coil or the start solenoid. If the cdi is open  on the power input side would that cause my problem. I have checked continuity on all wires.
JOB
« Reply #25 on: June 16, 2025, 04:13:32 AM »
I don't have a side stand safety. If the cdi power input was open internally would that cause my problem? I have checked continuity on all other ignition wires.
« Reply #26 on: June 16, 2025, 11:41:12 AM »
New CDI there?
-this big connector in good condition (both sides) and all pins straight and without corrosion?
-ignition coil, cable, cap, plug new?
-even you checked kilswitch, open again and bridge this two cables (green/white)
-all relays in your front new?
« Last Edit: June 16, 2025, 11:44:43 AM by Ruffus »
JOB
« Reply #27 on: June 16, 2025, 10:32:48 PM »
Rufus, I don't see any relays I the front section? The wiring diagram is un readable. Thanks Jeff
« Reply #28 on: June 17, 2025, 01:09:36 PM »
..no things like them under your front or somewhere?
This diagram mentioned should be readable..
« Last Edit: June 17, 2025, 01:13:43 PM by Ruffus »
JOB
« Reply #29 on: June 25, 2025, 02:19:15 AM »
Rufus I don't have either of those on my bike, a 2009 Kymco People 150. The wiring diagram is the same one I have 4 copies of, all of which are unreadable when you enlarge it enough to see some detail. I haven't been able to work on it for a week as I was waiting for the cdi which was lost in the mail. Hopefully I can get on it this weekend. Thanks for your help. Keep an coming.
