Author Topic: WTF my instrument cluster is dead????  (Read 30612 times)
darkshvein
Re: WTF my instrument cluster is dead????
« Reply #15 on: December 07, 2024, 12:59:17 AM »
I have exactly the same on my Xciting 2007 from today when I wanted to make a ride after 2 Months
How you solved the problem?
I note, that scoot side stand, when down or up, affect to electric on board display. Maybe contact of this cable/sensor.
« Reply #16 on: December 07, 2024, 05:33:57 PM »
If this scooter has been used in salty road conditions it might be a corrosion prob or finally a dry soldering spot in your cluster.
Pls try following:
-check plus and minus cables at battery
-all fuses out and renew
-make a direct cable battery minus to frame or any blank point at the motor (jumpcable)
-open this hatch at the middle tunnel (where the fuelpump is located under) and disconnect/clean/reconnect all connectors and
plugs
(sidestand light ON on dashboard?)
-take the front fairing off
-check all connectors
-move all relays
« Last Edit: December 09, 2024, 06:34:03 PM by Ruffus »
