Author Topic: Rear tire cracks  (Read 35356 times)
PiotrKymco
Re: Rear tire cracks
« Reply #15 on: November 23, 2019, 10:43:11 AM »
Same crap that happened to mine. https://www.kymcoforum.com/index.php?topic=26153.0
Not sure what model the rear tire was but it did show 69H for rating on the tire according to my old photos. I replaced it with the same size Bridgestone TH01R that my Burgman 650 uses. A special note I had a problem with the Bridgestone as well after a tire puncture but I think part of that problem is that Kymco lists too low of tire pressures for the weight of the bike (650 lbs) vs the Burgman 650 (615 lbs) which is 35 lbs lighter. I am now running 32 psi front and 36 psi rear in my Bridgestone vs the factory suggestion of 29 psi front and 32 psi rear.
I bought new tire Pirelli Diablo Scooter 160/60R14 ŚWIEŻE 160/60-14, hope will be ok for my beast. Any comments regarding that tire? I stay away from Maxxis tires.
MJR
« Reply #16 on: November 23, 2019, 02:13:43 PM »
If it's this Diablo https://www.amazon.com/Pirelli-Diablo-Scooter-Moped-60-14/dp/B000GV85PA you will be lucky to get 5,000 miles out of it. If it's the Diablo Russo I have no experience with it.
'03 Coast Cyan Atlantic 500
'14 White MyRoad 700i
'09 Mirage White Burgman 650
« Reply #17 on: November 23, 2019, 03:03:31 PM »
Was your bike designed for radial tires?
MJR
« Reply #18 on: November 23, 2019, 11:35:03 PM »
Factory equipped with radials.
PiotrKymco
« Reply #19 on: November 24, 2019, 11:34:10 AM »
Why you think only 5000miles and when Im lucky? Something wrong with that tires? That tires do not have bad opinion at all, so Im curious why?
PiotrKymco
« Reply #20 on: November 24, 2019, 12:18:56 PM »
The muffler has to come off. You can get the swing arm off after that with a pry bar holding the forward pipe out a bit. I ended up doing this on the centerstand, disconnected the rear shocks at the swing arm, pushed it up, prying on the exhaust pipe, and slid off the right side of the swing arm. You will need a long Allen wrench/socket to get at the bolts recessed in the swing arm.
Do you have maybe bolt and nut torques? Especially for wheel nut and swing arm? If yes and Nm will be great.
« Reply #21 on: November 24, 2019, 04:43:15 PM »
Maybe Maxxis have a special blend which adds these "rain sipes" as the tire ages?
« Reply #22 on: November 24, 2019, 08:58:58 PM »
Regardless of age, this tire is throwaway----although it will continue to hold air.
MJR
« Reply #23 on: November 25, 2019, 03:37:08 AM »
Sorry but the service manual lists them in kg-m so use a online converter to Nm.
Muffler mount bolt 3.2~3.8  kg-m
Exhaust pipe joint nut 1.0~1.4 kg-m
Exhaust pipe band bolt 1.0~1.4 kg-m
Rear swing arm Allen bolts 4 kgf•m
Rear lower shock mount 4.0 kgf•m
Rear axle nut 13 kgf•m
Rear caliper mounting 3.2 kgf•m
I've tried two sets on my B650 (same size), the last one was bald with cords showing with only 5,031 miles on them.
« Last Edit: November 25, 2019, 03:47:35 AM by MJR »
