Author Topic: My Setup so far ...  (Read 14905 times)
Raindrop586
Re: My Setup so far ...
« Reply #15 on: September 22, 2015, 11:22:35 AM »
Ya im gonna order the white malossi spring and light cltuch bell cause i have the racing clutch in with stock bell and converter . 2k springs . but this winter im still doing a full race kit . gonna redo bearings , gears whole nine yards . trying to find a cheap sand blaster for my garage .
I also was looking in putting the stage 6 r/t head kit on .
Just gotta 3 mill off head i was reading . and thats the 80cc kit
Triesandluth
« Reply #16 on: September 22, 2015, 06:45:18 PM »
80cc for a 2 stroke?
Raindrop586
« Reply #17 on: September 23, 2015, 01:33:32 AM »
I think its actually 86cc but not positive. But i think im gonna copy this setup . his bike is a monster wish he spoke english lol
Triesandluth
« Reply #18 on: September 23, 2015, 10:37:23 AM »
All I see from that is the 70cc airsal t6.  Unless you know of some after market bore job and porting.
I'd like to do some squish band lowering and porting,  myself.  Maybe this spring...
Raindrop586
« Reply #19 on: September 23, 2015, 05:55:28 PM »
Ok i think im close to figuring this thing out lol
Feel like dumbass. But had the hardest torque spring in .
What weights in rollers with a 1000k spring ?
I had the 2k one in . no wonder it just took off smooth and no lift . or am i wrong ?
Triesandluth
« Reply #20 on: September 24, 2015, 05:50:15 AM »
Those springs and rollers generally depends on your riding style,  your weight,  the terrain you're in,  and what kind of power you have. It's all kinda like a balancing act between all the cvt components.  Stiffer torque spring , in idea,  would benefit from heavier weights to encourage the belt to rise on the front pulley and lower on the rear pulley.  And the opposite for a lighter spring,  where is you had too heavy of weights it would force the rear to shift down faster due to the weights moving the belt up quicker on the variator.  It can take a bit of trial and error.  Then you also need to keep in mind that your new torque spring will be more stiff for a while as it settles in.  I took mine and stomped on it repeated for a few minutes before install.  Kinda took a bit of the stress off of it.  I wouldn't suggest that,  really.  Not sure if it was counterproductive or not.
Right now I run with the malossi variator,  9 gram rollers,  malossi delta clutch with white clutch springs,  middle setting, yellow NYC spring, 1500, but very used,  with the bearing kit to reduce spring friction,  which in turn makes the spring seem more stiff since it raises it a quarter inch or so.  My setup works great for me in the mountains of NC.  Almost no situations of bogging when coming out of corners.
Raindrop586
« Reply #21 on: September 24, 2015, 09:49:52 PM »
Spent some hrs trying diff setups . so far blue top racing spring 2k and 9gram rollers work the best . idk why just does lol
Filled the  holes that i drilled  back up on air box and 95 jet seems perfect but i got 2 more jets today if it starts to feel sluggish but so far she rips .
Cant wait to see what after market carb and intake does ?
Will i even notice ?
« Last Edit: September 24, 2015, 09:51:28 PM by Raindrop586 »
Triesandluth
« Reply #22 on: September 25, 2015, 05:55:41 AM »
I noticed a little with the bigger carb.  Like it rose in rpms quicker. I still have the stock intake,  barely opened it up,  not a strong enough Dremell tool.
« Last Edit: September 25, 2015, 05:38:37 PM by Triesandluth »
TheAmishSasquatch
« Reply #23 on: September 26, 2015, 06:59:41 PM »
I'd have to agree with the more open your carb is, then the quicker it gains rpm=speed. I've been running my bike with an open velocity stack  and it pulls and accelerates nicely. I mounted my old modified air box (which in a strange twist of fate, got me to my current setup as it ruined my stock engine/carb setting and cluster-f***ed from there). The mods made were I cut the cross bar on the inside which forms 2 small squares so that it makes one larger rectangle, and I opened the fake NACA duct on the air box cover into a functional duct. The plastic hose up top is disconnected from the bike and air filter removed.  Anyway I mounted this yesterday and adjusted my carb to compensate. I immediately noticed a lack of punch and slower acceleration. Top speed remains the same but took much longer to achieve. Today I swapped  back to the stack while them slow fools swing on ma sack!.... yes I really just dropped some beats up in here  8)
Triesandluth
« Reply #24 on: September 26, 2015, 07:54:17 PM »
Nicely executed!
As shown in my thread with pics of my airbox,  I opened all the entries drastically including the snorkel.  I didn't think about the rectangle thing.  I'm going out right now to delete that.  Any little bit helps, I suppose.
Triesandluth
« Reply #25 on: September 26, 2015, 07:54:54 PM »
What's NACA duct? Got a pic?
TheAmishSasquatch
« Reply #26 on: September 26, 2015, 10:35:05 PM »
You might be able to see it.
Triesandluth
« Reply #27 on: September 26, 2015, 11:34:37 PM »
I kinda had the idea that that was what you were talking about.  But doesn't that let air through without it passing through the filter?
I just deleted the little rectangle and the rest of the material down to match the contour of the outer cover.  Might free up a bit more air.  Didn't take it far,  had my daughter aboard.  I'll probably not be able to notice any difference.  Might notice more from painting that cover lol
TheAmishSasquatch
« Reply #28 on: September 27, 2015, 12:55:04 AM »
I have a filter, but not factory. Also, I've known of many people who run cone filters mounted within the stock airbox. I guess the box more or less acts to both suppress noise and allow all weather use without fear of water ingestion.
Raindrop586
« Reply #29 on: September 27, 2015, 05:08:35 PM »
I dont have large enough jet to run the stack on . soon as it rips off . and your right dude rips off . boggs down from lack of fuel . ill try this 105 i just got . but its last one my parts store has on stock . and since im waiting for 20mm intake to come in . might as well wait it out . s h i tt y i know
