@PR, welcome here in this KYMCO hive.
All you said already, plus I would do a CVT check,
means cover off, belt off, clutch off and rollers.
-Even there is not that much to be expected at this milage, it's nice to be sure
- Brake fluid change and brake pads inspected.
- It cannot hurt to unplug/ replug all connectors and lathering with dielectric grease not to have any electric surprises due to corrosion.
- Vacuum lines and ground points are sometimes an issue.
- sidearm bearing (rear wheel off)
- Muffler nuts (cylinderhead/pipe) coppergrease
- Brake calipers, take those two/ four bolts which hold brakepads out, and put coppergrease/ ceramic paste on it, to preserve (6mm L-key), lock tight tenderly
- Fuel filter change
- Odometer drive new grease and cable checking.
-Valve clearance .
