Author Topic: Bogging down HELP PLEASE  (Read 1759 times)
Skoty2hoty
« on: May 27, 2017, 03:15:12 AM »
I have a 2012 super 8 150.. i put new batt plug carb and tire on it got it inspected and on my maiden voyage with it made it a half mile down road and bogged down and quit.. started right back up and would run but once I gave it enough throttle to move it bogged down and when I let go would stay running but if I didn't would quit.. any help or suggestions are appreciated
Re: Bogging down HELP PLEASE
« Reply #1 on: May 27, 2017, 01:42:41 PM »
Are you saying you replaced the battery, spark plug and carburetor?  If so, why did you replace the carb?
Redk
« Reply #2 on: May 27, 2017, 03:09:52 PM »
Read the plug...
redk
Skoty2hoty
« Reply #3 on: May 28, 2017, 11:38:36 PM »
I replaced the carb cuz it wouldn't start
Mr. Paul
« Reply #4 on: May 28, 2017, 11:49:49 PM »
Check the vacuum line routing.
2009 Kymco People 150
1993 Honda Helix
Skoty2hoty
« Reply #5 on: May 30, 2017, 10:25:55 AM »
My man.. the vacuum line was in a comprised spot to where it was collapsing slightly.. good looking out thank you sir
Mr. Paul
« Reply #6 on: May 30, 2017, 09:34:59 PM »
Did it fix the bogging?
1993 Honda Helix
Skoty2hoty
« Reply #7 on: May 31, 2017, 09:46:04 PM »
Yes the vacuum line was kinked  and my ground for the auto choke had a short they were both in the same spot thank you for the idea it's helped
Mr. Paul
« Reply #8 on: May 31, 2017, 09:50:40 PM »
Great! Glad you got it fixed. Stick around. This is the best forum on the net. :)
1993 Honda Helix
Redk
« Reply #9 on: May 31, 2017, 09:59:05 PM »
This is good !
Patience and methodical inspection has brought an inexpensive fix !
Excellent !
redk
Pecygacrace
  • PecygacraceVC
« Reply #10 on: June 12, 2017, 06:18:44 PM »
did you just hit it with the sledge hammer from the all sides or did you hit it right on the front surface?
