Did you miss your
activation email
Scooters - 125 to 300
Super 8 150
SOLVED carb - pilot screw missing?
Topic: SOLVED carb - pilot screw missing? (Read 686 times)
lukasbasic
Jr. Member
2012 Kymco Super 8 150
April 17, 2017, 11:26:54 PM »
guys, look at the pic. where is it??? did it fall out? how does this scooter even go? would this mean that it runs super rich? I can't get it above 52mph, would that explain it?
Last Edit: April 25, 2017, 12:24:11 AM by lukasbasic
lukasbasic
Jr. Member
April 25, 2017, 12:23:56 AM »
thing has no screw.
Mr. Paul
Re: SOLVED carb - pilot screw missing?
April 25, 2017, 12:47:39 AM »
If the carb adjustment screw was missing, the scooter would be running super lean (not good) and would likely have trouble maintaining an idle. Do you see a screw on the side of your carb that appears to be brass and has a slot in it for a screw driver? Here is a link to a post with a good photo to give you an idea of the screw location. If you are missing it, it needs to be replaced before the scooter is run again.
http://itistheride.boards.net/thread/3806/carb-main-jet-gy6-150cc
Last Edit: April 25, 2017, 12:59:08 AM by Mr. Paul
2009 Kymco People 150
1993 Honda Helix
Back
